Gears vs. engine mods
Old Jan 2, 2006 | 02:27 PM
Sully0212's Avatar
Sully0212
Default Gears vs. engine mods
Okay, I think this will open a "can of worms" opinion-wise BUT, what do you all think is the best way to go for an initial investment (say under $2,000) in performance upgrades:
1. Replace the 2:73 differential with a 3:15 (or maybe a 3:42) and do a dyno-tune. I have the A4 transmission in my 2004 CE coupe.
OR...
2. Add an cold air intake, cat-back exhaust and then dyno-tune.
I want to keep the car pretty "tame and sane" as a driver, don't plan on racing it...mostly cruising, trips, etc.
thanks in advance for the opinions!
Sully
Old Jan 2, 2006 | 02:52 PM
mountainbiker2's Avatar
mountainbiker2
1.Sticky tires
2. gears
3.cold airbox.
4.Dyno tune
Old Jan 2, 2006 | 03:02 PM
sdnet's Avatar
sdnet
There's no question that you'll feel more of a difference changing gears to a more aggressive ratio. If I were you, I'd do 3.42s. The cat-back exhaust, however, would certainly make it sound nice, which really does add to the effect of a sports car.
Old Jan 2, 2006 | 03:05 PM
boatboatboat's Avatar
boatboatboat
It isn't worth your $ to do gears unless you do 3:73's.
yes 3:42's will be an upgrade......... but 3 weeks latter you will be wishing you had done 3:73's or higher.
Old Jan 2, 2006 | 09:32 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
Old Jan 2, 2006 | 10:22 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
Old Jan 2, 2006 | 11:34 PM
Face's Avatar
Face
Old Jan 2, 2006 | 11:42 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Plus no need for a dyno tune unless you do at least headers
Old Jan 2, 2006 | 11:56 PM
UpToVT's Avatar
UpToVT
Hey Ikester !!!
How would you know anything about GEARS ?!~???
Geezzzzzzzzzzzz
Old Jan 3, 2006 | 06:56 AM
Dark-Knight's Avatar
Dark-Knight
Defintly 3.42's and a tune/LS1 edit.
Old Jan 3, 2006 | 07:03 AM
AU N EGL's Avatar
AU N EGL
Automatics can get a lot out of a dyno tune.
IMHO a cold air intake and a 3.42 ( 3.73 if you drag race) and the dyno tune.
Old Jan 3, 2006 | 07:04 AM
gr8vet's Avatar
gr8vet
St. Jude Donor '06
Any data on how much fuel consumption will change on highway driving going to higher ratio? 3:73
Thanks in adavance.
tt
Old Jan 3, 2006 | 07:12 AM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
3.73 gears and a tranny tune (delete torque management, change shift points, speed and pressure).
Your PermaGrin(tm) will be so wide your face will hurt
EG
Old Jan 3, 2006 | 11:15 PM
Sully0212's Avatar
Sully0212
Default Any recommendation on purchase?
Okay,
It looks like the consensus is toward the gears (at least 3:42 and maybe 3:73). Where would you all recommend I look...used vs. rebuilt vs. new?
Also, what is the "hit" on drive-ability? I would assume less than the current 18/25 MPG to begin with.
thanks again for all the opinions! You all are great!
Sully
BTW, I live in Reno, NV so probably somewhere in Northern "Kalifornia" or possibly LA.
Old Jan 3, 2006 | 11:24 PM
navy99vert's Avatar
navy99vert
Cruise-In VIII Veteran
EG
Old Jan 4, 2006 | 09:15 AM
chaase's Avatar
chaase
St. Jude Donor '12
Originally Posted by Sully0212
Okay,
Sully
If you go with 3.42's you may be able to get some used from the many forum members here who have ditched there stock 6-speed rear-ends
Chris
Old Jan 8, 2006 | 09:58 PM
John Micheal Henry's Avatar
John Micheal Henry
Old Jan 8, 2006 | 11:25 PM
lost's Avatar
lost
If you are a good driver, gears will improve your times, but Ive seen a 2.73 rear car run in the 12s with just bolt-ons, no headers. Wheelspin is not a factor, as it would be with 3.15,3.42 or 3.73s.Putting sticky tires on changes the whole equation and you can expect .5 improvement with gears, add a torque converter and you can get more. Ive seen a Ls1 Camaro with less than 350 rwhp run in the 11s with just gears TC and bolt-ons. but more $ was put in the suspension and tires than in the motor to get those times.It depends on what you want, in other words there is more than one way to skin a cat!
Old Jan 9, 2006 | 10:15 PM
Sully0212's Avatar
Sully0212
Default Gear update
Right now I'm leaning toward the 3:42's. I can get a used unit with less than 10K miles for under $1,000 from Mallet. I think that this plus a good dyno-tune should put the "PERMA-GRIN" on my face for awhile. It should also keep me under the $2,000 budget I have set aside for mods. Cat-backs and CAI will have to wait for now.
Next, I have to find a shop to do the swap...any ideas? Northern Cal or maybe LA? I've heard of Synergy Motorsports (Fremont) and A&A Corvette (Oxnard).
thanks again for all the advice!
Sully
To Gears vs. engine mods
