Vararam air filter = junk.
Old Jan 2, 2006 | 02:29 PM
usnskeet21's Avatar
usnskeet21
Default Vararam air filter = junk.
I am in the process of yanking my no oil pressure having LS1 and building a 408 iron block. In the process of this i have noticed alot of dust and grit past the maf, tb and even into the intake manifold. I was not too fond of the foam filter when i saw it and how well( lack of ) it seals in the box. Has anyone put a paper or K&N filter in place of the foam vararam one. I dont want my brand new motor breathing all this junk. And if anyone wants to argue that not that much is getting into the motor shoot me your email adress and ill send you a pic of my number 1 plug that looks like someone diped in super glue then stuck it in a sand box!
Old Jan 2, 2006 | 03:24 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
they were supposed to have a better filter released.
Old Jan 2, 2006 | 03:34 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Been said time and time again, how do you think they get more air in.
It filters less. This is why, to me, it is not worth the 5 hp you get for the hundreds you spends and the dirt it lets in
Old Jan 2, 2006 | 04:18 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
You can use the K&N filter pn 33-2522
Old Jan 2, 2006 | 04:21 PM
edensknight's Avatar
edensknight
The foam filter is substandard to say the least! And, yes, they are being replaced with aftermarket K&N alternative filters by most of the disappointed consumers who purchase this particular unit. The other qualm is the fact that the unit (Vararam) is far too cumbersome to install, often necessitating modification and extra drilling, on top of the high cost for the unit itself, plus another aftermarket filter! Recently, a supporting vendor has advertized the Vararam with a newer filter ("the green filter"). Therefore, to each his own. Virtually any aftermarket air iflter intake does offer more breathability over stock.
Old Jan 2, 2006 | 06:50 PM
Patman's Avatar
Patman
The new Vararams come with a green filter or another type of cotton gauze filter (that's the one I received with my recent order) They haven't come with the foam filter for a while now I believe.
Old Jan 2, 2006 | 06:57 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
i saw one car this summer that had the v.ram installed, the filter had fallen apart and became useless
Old Jan 2, 2006 | 08:32 PM
Billdog350's Avatar
Billdog350
The 33-2522 K&N is a drop in replacement for the crappy foam thing they call a filter? If so that would be great!
Old Jan 2, 2006 | 08:58 PM
John S.'s Avatar
John S.
after 2000miles with my vararam and seeing a bunch of **** in my tb I decided to switch to the bpp vortex rammer and couldnt be happier. vararam is a complete pile of **** and looks like a 4th grader made it. I settle for a 3hp loss to gain the comfort of knowing I'm not sucking **** into my engine.
Old Jan 2, 2006 | 09:05 PM
C5Jimmy's Avatar
C5Jimmy
Thats why I'm going either Halltech R or Vortex!
Old Jan 2, 2006 | 10:44 PM
ericdwong's Avatar
ericdwong
Yeah whoever made this thing should be shot. Cant they even OEM airbox quality? Expect to see mine for sale pretty soon.
Old Jan 2, 2006 | 10:55 PM
usnskeet21's Avatar
usnskeet21
Who has done this?? True?
Old Jan 2, 2006 | 11:03 PM
shurite44's Avatar
shurite44
I believe vararam has a new filter. I never had any problems with the foam filter on two C5's.
Old Jan 2, 2006 | 11:10 PM
John S.'s Avatar
John S.
I have done this with my vararam just before I sold it. It isnt a straight drop in. You will need to get some weather stripping and glue it around the k&n filter to get it to seal. Its not hard but its way too much rigging for a $350 intake that already looks rigged from the get go . Did i mention I hate the vararam
Old Jan 2, 2006 | 11:36 PM
EHS's Avatar
EHS
Not another Vararam bashing thread.
Old Jan 3, 2006 | 07:18 AM
Special K's Avatar
Special K
K&N for the vram isn't much better than foam.
http://home.usadatanet.net/~jbplock/ISO5011/SPICER.htm
Old Jan 3, 2006 | 08:43 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
NCM Ambassador
A couple of green filters are on my list
To Vararam air filter = junk.
Old Jan 3, 2006 | 09:25 AM
wolfman04's Avatar
wolfman04
Here is a pic of one of there new filters.
Old Jan 4, 2006 | 06:49 AM
Patman's Avatar
Patman
That is the filter I received with my Vararam a few weeks ago, although when I ordered it from LAPD they said it would come with a green filter.
Does anyone know who makes the filter in the picture above?
Old Jan 4, 2006 | 07:03 AM
tntmask's Avatar
tntmask
Cruising
The K&N filter pn 33-2522 is a direct replacement...I just did it this past weekend. No problem...great fit.
