Vararam air filter = junk.
Old Jan 4, 2006 | 07:41 AM
RED99's Avatar
RED99
Originally Posted by Patman
That is the filter I received with my Vararam a few weeks ago, although when I ordered it from LAPD they said it would come with a green filter.
Does anyone know who makes the filter in the picture above?
GREEN is the manufactor of the filter.
Old Jan 4, 2006 | 08:30 AM
itsmeek's Avatar
itsmeek
http://forums.corvetteforum.com/show...m&forum_id=103
see this thread..
Old Jan 4, 2006 | 08:32 AM
itsmeek's Avatar
itsmeek
hi are you sure this is a green filter. nowhere on this filter does it say it's made by green and when i called vararam about it (i was told i'd get a filter made by k&n) they told me it was developed to work like a green filter.
Old Jan 4, 2006 | 08:39 AM
rws.1's Avatar
rws.1
Where is everyone buying the K&N filter pn 33-2522?
From The LAPD? a local part store via special order?
Old Jan 4, 2006 | 06:49 PM
John S.'s Avatar
John S.
Originally Posted by tntmask
The K&N filter pn 33-2522 is a direct replacement...I just did it this past weekend. No problem...great fit.
you may want to double check that fitment. you will have to add some weather stripping to get a good seal.
John S.'s Avatar
John S.
i believe i got mine from summitracing.com
Old Jan 4, 2006 | 07:52 PM
Z06ufgrad2002's Avatar
Z06ufgrad2002
Originally Posted by usnskeet21
Who has done this?? True?
Yes, it will drop right in but, don't expect a perfect seal with that filter element either. You have to trim that K&N filter and use some foam to make it fit snug.
If you are sticking with the Vararam box I would suggest gettting the new Green filter that vararam is selling.
Old Jan 5, 2006 | 06:03 AM
Patman's Avatar
Patman
But the green filter is actually green in color, so it can't be that.
Old Jan 5, 2006 | 06:34 AM
Z06 Steve's Avatar
Z06 Steve
yes the foam filter is crap...I have a KN replacement and its far from a drop in.I sealed mine to the upper air box with RTV.On the lower air box I added some foam to add to the non existant sealing qualities.The design of the air box will and cannot promote a leak free seal unless modded.
Old Jan 5, 2006 | 10:00 AM
itsmeek's Avatar
itsmeek
haha...i called and asked them about 20 times whether this is the green filter and they told me there was no green filter.
Old Jan 5, 2006 | 11:39 AM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
We recently installed a VR2B from LAPD with the non-foam filter in my buddy's '04 Z06. We were more than disappointed when trying to button up the two halves with the filter in between. Getting it to fit right and seal is a two man job and took many tries to get to where the 'pressure test' would pass. The halves would not stay together right and the side of the filter is visible which is not a big deal but it is FAR from a factory fit. If there is any sign of dirt past the filter when the element is cleaned the VR will probably come out in favor of a zip tie/K&N mod.
I used to be a big fan of the VR because of the #'s it puts out and the theory behind it but the quality is poor. I'm sorry I recommended it to my friend. Definite buyer's remorse.
Old Jan 5, 2006 | 11:58 AM
ArKay99's Avatar
ArKay99
Weird, I bought my VaraRam about 2 years ago from WCC I believe, and it came with a K&N. I just installed it and havn't had any problems with it since.
Old Jan 6, 2006 | 06:01 AM
  #33
Patman's Avatar
Patman
When I got my Vararam installed I was a bit worried about the air filter sealing up properly too, but the installer showed me how it fit in there before he closed it up and there is no way air was going to get past mine. The fit was perfect on mine, and that filter is in there good and tight with no leaks.
Old Jan 6, 2006 | 04:41 PM
  #34
wolfman04's Avatar
wolfman04
Default Here is a reply I got from Vararam on a e-mail I sent.
The green is 1 ¼ inch thick the gray is 7/8ths thick. This alters the ram effect. The green is $59 the gray is $39
Regards VR tech
To: sales@vararam.com
Subject: New Filter
Is there any different between the Gray filter and Green filter or are they the same filter for the VR-B2, what is the price?
