GM CNC ported heads?
Old Jan 13, 2006 | 11:29 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Mine are the 60 cc head. I've never had a problem with knock.
I run NGK TR6s in the summer heat and TR55s the rest of the time. Running a cooler thermostat helps of course - I run a 176*F Tstat in summer.
Old Jan 15, 2006 | 03:45 AM
turboc5's Avatar
turboc5
Old Jan 16, 2006 | 10:55 AM
aTX427
Guest
Posts: n/a
How do these compare to full CNC ported AFR's?
Old Jan 16, 2006 | 11:48 AM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
Originally Posted by turboc5
Wow thats impresive, I would be very happy with 450rwhp. Since you have 61cc heads, how is it on pump gas? Thanks for the offer but I too work at a dealership that sells cadalic. Thats what got me interisted in the heads and then I found out Lingenfelter did all the work.
I have never had a problem with detonation. My tuner put in bigger injectors just to be sure and the a/f ratio is just right. I also run the NGK's and a 160 degree stat.
Old Jan 16, 2006 | 06:13 PM
RobWS6's Avatar
RobWS6
I'm running the 65cc heads on my GTO along with the baby cam GT2-3. Only put up 390/380 after tuning. Runs absolutely perfect and sounds completely stock. Very nice sleeper package. Waiting for the tracks to open to see how it does. Previous cam only ran 12.57@111.71.
But I think I'm going to step up on the cam after this summer. What's everybody running? I see a couple are running bigger cams with very good results I want a cam that matches the flow characteristics of these heads. So it looks like .600 lift would be the max from the flow results I've seen.
FWIW, mine are untouched. I do run a .045 Cometic gasket to bump up the compression to about ~10.7:1.
Old Jan 16, 2006 | 06:57 PM
RichieRichZ06
St. Jude Donor '08
I have a 228/228 .590/.590 112lsa and it is great. It has a muscle car idle that shakes the antenna back and forth and pulls all the way to 7,000 RPM. Iv'e had many people come up and ask why my new car sounds like a nascar.
Old Jan 16, 2006 | 08:45 PM
Greg_E's Avatar
Greg_E
[QUOTE=turboc5]Thanks, Is detonation a big problem with the 60cc heads? I wil use the mls head gasket, at least thats are what people are recominding. The car no longer is my dd, just my toy. I don't mind it being a little radical on the street but if I track it I will put some 100 octane fuel in it. As long as I don't advance my timing too much I should be ok with the 60's right? If I go with the 65cc heads wil I lose much power? I wan't to keep the cr as high as I can and still drive it on pump gas, race it on 100. With the asa cam I would think it should blead off a lot of cylinder pressure and make it more pump gas freindly. Thanks for your expert opinion
In the really hot summer weather, I sometimes get a little detonation, so I just blend a few gallons of 100 octane in a tankfull of 93. When it's a little cooler, it's fine on 93.
