Installing Body Side Moldings
Old Jan 16, 2006 | 08:00 PM
GWD, JR's Avatar
GWD, JR
Default Installing Body Side Moldings
Anybody got measurements or a place that I can get a template for installing body side moldings. Got em painted just need some directions on where to place them?
Old Jan 16, 2006 | 08:41 PM
GWD, JR's Avatar
GWD, JR
Please Help
Old Jan 16, 2006 | 09:02 PM
RonJ's Avatar
RonJ
Here goes, I'm typing this from a 98 service manual.
Using a flexible tape measure, locate and mark with masking tape the mounting position of the moulding.
. The distance from the forward upper edge of the fender down to the top of the moulding is 335 mm (13.2")
. The distance from the bottom of the door handle key hole opening down to the top of the moulding is 195 mm (7.8")
. The front edge of the moulding is positioned 5 mm (0.2") rearward of the front edge of the door.
On the front fender: Position the moulding forward of the rear edge of the fender 3 mm (0.1") and in line with the door moulding.
Hope this helps you out and good luck!!
RonJ ...
Old Jan 16, 2006 | 09:11 PM
GWD, JR's Avatar
GWD, JR
Thank you very much. Will go with that.
To Installing Body Side Moldings
