Motor pull through top tomorow.
Old Jan 4, 2006 | 11:48 PM
usnskeet21's Avatar
usnskeet21
Default Motor pull through top tomorow.
I will be pulling my motor through the top tomorow. I already have the intake manifold, heads, water pump, alt, etc off or tied out of the way. I will be removing the steering rack. I am still a litle uncertain about what all i need to do to get the torque tube out if the motor now. Any body mind giving me a run down of what is got to go on back there or have some links. I am good witheverything else just never messed with the whole clutch/torque tube assembly befor. Thanks !!
Old Jan 5, 2006 | 02:42 AM
CrazyChris's Avatar
CrazyChris
You need to unbolt the torque tube from the bell housing. It's only 5 or six bolts. Then pull the motor forward until it clears the shaft and then up. The clutch/flywheel/bell housing stays connected to the motor. Once the rack is out it is cake.
Old Jan 5, 2006 | 08:50 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Some reading, you are almost ready
http://forums.corvetteforum.com/show...um_id=1&arch=1
Old Jan 5, 2006 | 10:29 AM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
That's how my brother-in-law and I have done it as well.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Jan 8, 2006 | 11:59 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Please post your comments as I will be doing this in the next week or two.
To Motor pull through top tomorow.
