Air Conditioning problem???
Old Jan 5, 2006 | 01:53 AM
WantstobuyaVette's Avatar
WantstobuyaVette
Default Air Conditioning problem???
Since I bought my 98' Vette the display on the A/C has never worked but the air condtioner has always worked fine.
Now it wont blow cold air though. Everytime I put hit the A/C button it blinks a couple of times then it puts the vent on. With the display not working I really dont know what the A/C is doing. Any idea why its suddenly not working? Could it be something simple?
I rather just keep it then poay $500+ for a whole new unit.
Old Jan 5, 2006 | 02:17 AM
edensknight's Avatar
edensknight
Definitely perform a manual diagnostics to see what specific trouble codes you may be throwing related to the HVAC problems you are experiencing. Right off the bat, you appear to at least have the temperature actuator failing. However, perform the diagnostic to narrow down the culprit causes. Hang in there.
Old Jan 5, 2006 | 02:28 AM
WantstobuyaVette
Exactly how is a manual diagnostic done? I know that I sound like a noob.
Old Jan 7, 2006 | 05:18 PM
WantstobuyaVette
ttt
Old Jan 7, 2006 | 08:17 PM
wps5's Avatar
wps5
see if this help...It is an easy fix. I had the same issue. Here is the step by step http://corvettefever.com/howto/153_0307_batt_c5/
Old Jan 7, 2006 | 08:26 PM
dpd's Avatar
dpd
your either low or out of refridgerant.that's why the light blinks and goes to econ.it knows that youwant a/c but the pressure switch is telling the a/c head that the juice is low.that means no a/c compressor engagement
Old Jan 11, 2006 | 12:54 AM
WantstobuyaVette
that makes sense b/c the AC still allows me to adjust to HIGH/LOW but I can only adjust the vents air temp.
Where can I get a refill on refriderant? And is it hard to refill?
Old Jan 11, 2006 | 12:57 AM
WantstobuyaVette
Im still not making the connection here...a leaking battery can actaully cause the AC to not work b/c of the wiring underneth it?
Old Jan 14, 2006 | 02:16 AM
WantstobuyaVette
How do I check and change if needed?
Old Jan 14, 2006 | 11:29 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The leaking battery puts acid on the wirig harnesses, PCM and chassis components! NOT a good combo! The vacuum lines for the AC and A.I.R. controler run through the wiring harnesses. The acid causes the plastic vacuum lines to DISOLVE. When that happens, your AC will work but you will loose all of the vacuum that controls the vents and the air will "NORMALY" only blow out of the defrost vents and you will not be able to redirect it with the controls.
Probably not that, but something every should whatch out for. Once it happens, it's TOO LATE! Best ditch the old DELCO and get something else!
BC
To Air Conditioning problem???
