Headlight Problem (tried search)
Old Jan 5, 2006 | 09:33 AM
TSDuke's Avatar
TSDuke
Default Headlight Problem (tried search)
My drivers side headlight will not go down. I can lower it manually, then turn the lights on, & it pops right back up, but won't go back down. So to recao, it will go up on its own, but not down. Do I need to replace the motor, or is there another fix.
Thanks in advance.
-Tucker
Old Jan 5, 2006 | 03:42 PM
aj98's Avatar
aj98
Originally Posted by TSDuke
My drivers side headlight will not go down. I can lower it manually, then turn the lights on, & it pops right back up, but won't go back down.....
Thanks in advance.
-Tucker
Along with the fail to retract, does it also make an obnoxious buzzing noise when you turn off the lights?
AJ
01 NBM Coupe
Old Jan 5, 2006 | 04:02 PM
TSDuke's Avatar
TSDuke
AJ
01 NBM Coupe
No, there is no buzzing noise.
Old Jan 6, 2006 | 02:56 PM
aj98's Avatar
aj98
Hmmm.
I ask b/c along with the failure to close, the 'bad' side also made a grinding buzz (like stripped gear teeth) for several seconds after turning off the lights.
Replaced the motor fixed both the buzzing and the failure to retract.
AJ
Old Jan 6, 2006 | 06:31 PM
Hiteck's Avatar
Hiteck
There's a recall on the drivers side headlight, I think for the exact problem that you are talking about. I had problems with mine being slow to pop up. So instead of checking the forum for answers, I pulled the headlight motor apart and messed it up. Had to have it replaced. Check your local dealership. As scary as that may sound, it may save you some pain and $$$.
Old Jan 7, 2006 | 06:03 AM
c3andc5's Avatar
c3andc5
When you turn off the headlights does the driver's side go down and then come right back up? If so, there is a technical service bulletin out on that and here it is.
http://www.corvetteactioncenter.com/....php?qstId=252
Old Jan 7, 2006 | 06:06 AM
DeeGee's Avatar
DeeGee
I was working the headlights on one occasion and managed to blow a fuse. I then had the same symptoms. Its an obscure fuse in the panel in the passenger footwell.
I found it by trial and error but another member who I mentioned this to who had a similar problem reckoned it was #6.
Top tip, don't forget the fuse panel cover fits upside down. Otherwise you'll have many happy hours trying to get it back on
Hope you fix it.
Old Jan 7, 2006 | 09:54 AM
TSDuke's Avatar
TSDuke
Thanks guys! I bought a used motor from a forum member, but I'll try the fuse thing first. Love this site!
To Headlight Problem (tried search)
