Manual Remote Start Experts Needed!
We figgured out the car would not remote start due to the fact that the brake wire was transmiting ground/power one after another and it kept the RM starter from starting.
Now what do you guys do? Cut the wire and add a switch or is there another way around this?
Now when you hit the break switch usually it emmits one positive signal and the alarm recognizes and switches over... only problem is when the probe on the switch it emmits ground/power a few times one after another so it confuses the system and it shuts down. So what I have to to is intigrate a seperate switch in my console that ones I get it I put the key etc. and flip a switch ... i guess only way to go about it.
Hope this helps.
It took me about 2 hrs to pre fab the work but this is how I did it and I think it is so far proven to be very safe.
Here is a crapy pic of what it looks like sorry its been taken with my phone my cam broke.
Anyhow this is what I did.
Bought magnetic window switches (the kind for anti theft that when brake appart will sent signal and alram will sound. If I can remember we used the Closed window switches so when the 2 come in near distance they will sent a signal and alarm will not work.
I used plubers tape as brackets and two of those locking O-ring's to secure the front and back magnets. Very tight secure fit + the magnets themselfs have two screws going through eachother as an added safety. It is very stiff on the stickshift and will not move even with some brute force =) made sure of that.
Also then I have two brackets per side for the other magnets that are on the outside of the booth locked by the stock 4 screws that are surrounded by the heat shield rubber.
Anyhow car will not start in any of the gears now but when the stick is in the neutral position it is furthest away from the magnets and will RMstart! anyhow this is a bit hard for me to explain but it worked really well!!!!
I have put everything together and tested it a dozen times to double and tripple check!~!!! I will not rely on it and it probably needs a check once every month or so just to make sure its still intact but I secured everything twice as good as it should!
So yes my car is now compatible even with a stickshift!
glad to hear you finally got it figured out.
