Fuel Guage problem
Old Jan 6, 2006 | 12:30 AM
Flowconpc's Avatar
Flowconpc
2nd Gear
Default Fuel Guage problem
Hey all
I am new to the Forum . Wonder if some one can help me out .
I have a 2002 White Corvette Coup 3& K Miles . Last week I inadvertantly filled my car up with fuel that was 10 % ethanol .
Now less that about 60 miles later my fuel guage will not register at all.
Also I notice that my digital guage is telling me that my car is low on fuel. It originally moves to full when I start the car but then it settles
on empty , the check engine light is staying on as well.
Any Ideas would surely be appreciated.
Old Jan 6, 2006 | 01:40 AM
Shane_S's Avatar
Shane_S
You might have toasted your sensor in the gas tank with that ethanol. Try filling up with 93 and adding a bottle of Techron from Chevron in there.
And since real high octane fuel will fry your O2 sensors that might be why you have a check engine light.
The fuel level problem is quite common
Shane
Old Jan 7, 2006 | 03:36 PM
Flowconpc's Avatar
Flowconpc
2nd Gear
Shane
Hi Shane
I have put a bottle of Techron in the Car , but I noticed that as I go through a computer reset that I have several codeless entries , can this be part of the problem ? How might I reinstall all these codes?
Old Jan 7, 2006 | 03:54 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Originally Posted by Flowconpc
Hi Shane
It works, it might take 2 tanks and 4 bottles but it works.
Then just use 2 bottles every 3000 miles and you'll be all set.
Old Jan 7, 2006 | 04:23 PM
lost's Avatar
lost
Techron did nothing for me, tried Berryman B-12, took three tanks but finally cleared up, and Berrymans is half the price of Techron, been using small amounts of acetone a proven mileage improver and also a very powerful solvent, at 6oz to the tankful, getting me a whopping 1.2 mpg, or 7% increase and hopefully keeping contacts on fuel sender clean. Acetone in gallon quantities only costs about $.09 per oz or $.54 per 18 gallons, Read all about it! http://www.pureenergysystems.com/new...00069_Acetone/
To Fuel Guage problem
