Exedy replacement discs?
Old Jan 6, 2006 | 04:53 PM
usnskeet21's Avatar
usnskeet21
Default Exedy replacement discs?
Well i pulled my motor today and while taking the clucth/ flywheel off. I pulled one of the discs out of the clucth and noticed how thin they are. Does anyone know what the spec is new, as far as Friction material/disc/friction material. (thickness) I would much rather replace it now while its out of the car than have to do it down the road. If any vendors give me info i will more than likely buy from you because i cant find ANYTHING online for replacement parts. Thanks
Old Jan 7, 2006 | 06:36 AM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Japanese clutch look it may be in there
http://www.daikin-clutch.com/technical/index.shtml
