balancing clutch and flywheel
Old Jan 6, 2006 | 06:46 PM
hpcubed's Avatar
hpcubed
Default balancing clutch and flywheel
For those who have had a machine shop balance your clutch and flywheel, where were the weights installed? In the holes on the flywheel or on the pressure plate housing? This may sound like a stupid question but the machine shop that did mine welded some weight on one side of the clutch and grinded a little off the other side. Is this an acceptable method?
Old Jan 6, 2006 | 06:50 PM
NV MY C5's Avatar
NV MY C5
Senior Member
Cruise-In V Veteran
Default re.
They welded weights to my pressure plate. It made a huge difference!
Old Jan 6, 2006 | 06:55 PM
hpcubed's Avatar
hpcubed
OK that makes me feel a bit better. I have heard of a few clutches that have blown up and it isn't pretty. Anyone else?
Old Jan 7, 2006 | 10:08 PM
MadBill's Avatar
MadBill
The balance job on a stock rotating assembly '02 Z06 I'm involved with is just being completed. I don't know how yet how the flywheel and clutch came out but so far the procedure went like this:
o Equalize piston weights to 1/4 gram (they seemed to be from two batches or something, as most weighed either very close to 'X', or to X + 8 grams)
o Equalize big and little end weights of rods (didn't hear how close they were)
o Fit appropriate bob weights to rod journals and zero balance crank (again, no numbers yet)
o Install harmonic damper and zero balance crank/damper assembly by removing weight from damper. (Tilt! Bad runout and over 12 grams out of balance! Plan 'B': New ASP or ATI damper and carry on.)
o Next the flywheel will be bolted up and zero balanced and finally
o The pressure plate will be bolted up and again zero balanced.
This way, if any parts are changed later, they can be zero balanced alone, leaving the rotating assembly correct as a whole.
To balancing clutch and flywheel
