Clutch master cyl
Old Jan 8, 2006 | 11:41 AM
Classical Glass's Avatar
Classical Glass
Default Clutch master cyl
I have a 2002 LS1 6sp convt. I want to remove the stock clutch master cyl and replace it with an adjustable one. How much is involved in the job and is there anything I should be aware of? Thanks in advance.....
Old Jan 8, 2006 | 11:46 AM
WKMCD's Avatar
WKMCD
The biggest PITA is that you have to get to the slave to bleed the system. There should be a howto around here somewhere or on LS1HOWTO.COM
