03 Z06 EBCM and Steering Sensor
got a bunch of codes yesterday, all point to a bad Steering Sensor, but I'd like to check and clean all connections first before I replace it. Anyone know the locations of the referenced parts? Is the Steering sensor in front of or behind the firewall? Thanks in advance.
The codes will give you a more precise area to look at, but these are some of the common problems
C1282
C1283
C1284
C1285
C1287
C1288
C1296
my last wheel alignment is around 2 years old. A friend also suggested my Euro tailight harness could be a problem, all the lights work right, but I need to clean the connections as well.
I can reset any single code, and they all reset and I hear a servo type noise in the steering column as the codes all come back (I have to scroll up one and then back and they are all there). My Optima battery is old, but it cranks the car like it's new.
Anybody know were the EBCM is so I can check the connections? The Steering sensor location as well?
Thanks!
