Valve spring seat question- picture
Old Jan 10, 2006 | 08:20 PM
Rhode Warrior's Avatar
Rhode Warrior
Default F11 cam, Valve spring seat question- picture
I have a Futral F11 cam. This is one of the valve spring seats and shims that came with my Manley dual springs from Futral. Does anyone know what the purpose of the shim is? Is it necessary?
Old Jan 10, 2006 | 08:22 PM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
Do you have hardened spring seats already? If not the shim could be for a spring seat base, or to acheive the proper preload.
Old Jan 10, 2006 | 08:24 PM
Rhode Warrior
These are to replace the stock seats. They came with the package.
Old Jan 10, 2006 | 08:47 PM
jers98vet's Avatar
jers98vet
How many shims came with the kit? What is the recommended installed spring height? They could also be used to achieve proper seat pressure according to your cam. Just a few things to consider.
Old Jan 10, 2006 | 08:57 PM
Rhode Warrior
16 shims came with the kit. I don't know the recommended spring height. Are the shims usually installed below the seats or above?
Old Jan 10, 2006 | 09:04 PM
jers98vet's Avatar
jers98vet
I cant say for sure where to put the shims on an lsx head, but on my old school big block I'd shim the spring between the top of the spring and the retainer.
You could try to install one spring without the shim and check the spring pressure. If the pressure is adequate for the cam you are running then I'd say you're fine without them.
Old Jan 10, 2006 | 09:09 PM
jers98vet's Avatar
jers98vet
I just read this post again and you may indeed have to use the shim in between the seat and spring to reduce wear on the bottom of the seat. In any case, good idea to at least measure seat pressure when installed so as not to cause premature wear on the cam/lifters.
Old Jan 10, 2006 | 09:21 PM
see5's Avatar
see5
I would sure ask Futral. You need to know installed height. Not to guess.
Old Jan 10, 2006 | 09:30 PM
dpd's Avatar
dpd
the shim is to adjust valve spring installed height[for example,early ls6 motors used them,late ones don't,i think].you may/may not need them[look at info that came with kit].shims are usually used after a valve job[where seats/valves are reground]to reset installed spring height.stock spring height on a ls6 head is 1.82 in.on a ls1 head it may be different,you'll have to get the spec,once again look at your info,it should say something,if not call the spring/cam company.if the installed height is supposed to be stock,you'll have to get it,assemble the heads and measure installed height.that will dictate the shim.if you have a shim originally,you'll probably need to replace them with the new ones as long as they are the same thickness
Old Jan 10, 2006 | 09:37 PM
Rhode Warrior
Thanks for the replies, guys. No instructions or specs came with the kit. I'll just have to wait until tomorrow to talk to Futral.
Old Jan 11, 2006 | 06:19 AM
vettenuts's Avatar
vettenuts
You not only need to know it, you need to measure it. Find out what Futral recommends for seat pressure, very important to prevent valve bounce on an aggressive cam. Then you need to install to that seat pressure. 130-140# for the LS1 was recommended to me by a very "in the know" person who consults to the racing industry.
To Valve spring seat question- picture
