Rod Bolt Upgrade?
Old Jan 11, 2006 | 11:04 PM
3Vettes@Home's Avatar
3Vettes@Home
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Default Rod Bolt Upgrade?
Has anyone changed rod bolts to Katech bolts? How difficult is the swap? I installed my own heads/cam pkg, so I do have mechanical abilities. I've been told with what I am now runing on my FRC, the stock bolts aren't strong enough. Thanks for any advise!
Old Jan 12, 2006 | 05:01 PM
molson's Avatar
molson
There is a lot of info on this over in LS1-tech.
Old Jan 12, 2006 | 07:03 PM
turboc5's Avatar
turboc5
I too want to put katech bolts in my frc. I was worried about balence issues. Has anybody done this without rebalencing the engine? I use my car at track events, not much drag racing.
Old Jan 12, 2006 | 10:42 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
I would bet everyone have replaced these without re-balancing.. Simply not an issue.
Old Jan 13, 2006 | 12:38 AM
ArKay99's Avatar
ArKay99
I've done it with ARP PRO's. I have about 4k miles on them now. Many trips to 7000 rpm's, and no issues, with balance, oil pressure etc. Katech states that their bolts will not distort the rod. ARP states you need to resize the rod after install. I did't resize my rods, but I torqued them according to ARP's suggestions with lube, and went over them one last time after all were installed. Then I kept the motor below 3k rpm's for the first 200 miles and below 4k for the next 200 miles. Not saying that you will need to do this, I just wanted to give the bearings a chance to re-set if they did indeed distort. I'm thinking they didn't because my oil pressure stayed.
Do the Katech's and follow their procedure and you will have no problems.
Old Jan 13, 2006 | 08:49 AM
3Vettes@Home
Cruise-In V Veteran
Thanks guys
Old Jan 13, 2006 | 06:56 PM
turboc5's Avatar
turboc5
Old Jan 13, 2006 | 09:50 PM
davidfarmer's Avatar
davidfarmer
if you are keeping your 97-00 engine below 6500rpm, stockers are fine. If you get a rod/rod bolt upgrade, you are safe up to 6900rpm
Old Jan 15, 2006 | 03:47 AM
turboc5's Avatar
turboc5
Ops, I was pushing mine to 6700 That could of been bad. I don't want to pick up my engine with a shovel
Old Jan 15, 2006 | 06:18 PM
Oneeye's Avatar
Oneeye
In a post on Ls1 Tech one of the guys from Katech said to give
them a call and they would be happy to answer any questions.
It seems to me the swap would be easy(but messy)if you can get
the oil pan off,with the motor in the car. Anybody do this or know
if you can?
Old Jan 15, 2006 | 06:40 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Just and FYI so some people on here don't freak out. 2001+ LSX motors recieved upgraded bolts and are not subject to the issues of pre '01 motors.
'97-'00 engines were subject so some rod-bolt failures in racing conditions seeing upwards of 7000 rpms for extended periods.
To Rod Bolt Upgrade?
