DIC light won't go off
Old Jan 12, 2006 | 01:03 AM
Caveboy's Avatar
Caveboy
Active Streak: 90 Days
Default DIC light won't go off
My HUD switch and my DIC back lights stays on still after I removed the key from the ignition. All the other lights work properly. Can anyone help me troubleshoot this issue?
Old Jan 12, 2006 | 01:16 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You possibly have one or more of the following problems:
1- One of the connector plugs on your gauge cluster is loose and not completly connected.
2- The chassis ground for that circuit is corroded, loose or broken.
3- BCM or guage clusted circuit board is wet damp or has corossion on one of the circuits on the board.
Check for DTC codes and see if any are set.
BC
