Cooling fan temps
Its not much different than what vett747 said, not sure which one is correct.
f.y.i.
Drain and Fill procedure
1. Park the vehicle on a level surface.
2. Follow the steps below to remove the radiator sure tank fill cap :
a. Slowly rotate the cap counterclockwise.
b. Stop and allow the hissing to stop.
c. After all hissing stop, continue turning counterclockwise to remove the cap.
3. Opens the radiator drain ****. (It looks like a white plastic plug below the lower radiator hose. You can see it if your car is jack and you are under it).
4. Allow the system to drain completely.
5. Inspect the engine coolant:
-Discolored – Follow the flush procedure below
-Normal in appearance –continue the next step
6. Close the radiator drain ****.
7. Fill the system through the radiator surge tank opening up to the base of the neck.
8. Start the engine.
9. Idle engine for 1 minute.
10. Install radiator surge tank cap.
11. Cycle the RPM, idle to 3000 for 30 seconds intervals until engine coolant reaches 210 F.
12. Shut off the engine.
13. Refer to step 3 above to remove the radiator surge tank cap.
14. Start the engine.
15. Idle engine for 1 minute and fill surge tank to ½ above COLD Full mark on the radiator surge tank.
16. Install the radiator surge tank cap.
17. Cycle the RMP, idle to 3000 in 30 seconds intervals until engine coolant reaches 210 F.
18. Shut off the engine.
19. Top off coolant as necessary, to ½ above COLD Full mark on the radiator surge tank.
20. Rinse away any excess coolant from the engine and the compartment.
21. Inspect the concentration of the coolant.
Flush Procedure.
1. Block the drive wheels.
2. Place the transmission in Park or Neutral
3. Press the parking brake.
4. Run the engine until the thermostat opens.
5. Stop the engine
6. Follow the drain and fill procedure using water until the fluid is nearly colorless. Refer to Draining and Filling Cooling System.
7. Fill the cooling system. Refer to Draining and filling cooling system.
How do you like that YZ?
My son rides the Yamaha 225, he's just a beginner. I can't ride that bike, too slow, soft squishy handling, no suspension, etc. Good learners bike, not for be.
I would like a mod with which I could switch the fans on manually via a dashboard switch, but I think there is none like that available.
Mine's a 2001, and I couldn't find the info in the shop manual last night (anyone else think that the shop manual index for these cars STINKS?) -
I'm wondering approximately what page and section of the '97 shop manual Vette747 found the info in?
For the 2004 model, the manual says lo speed on at 226, off at 219; hi speed on at 235, off at 226. Both fans run in series for lo speed and run in parallel for hi speed. With ac on, fans run at lo speed if coolant temp is above 185 and vehicle speed is less than 35 mph.
As an additional bit of info: Using the Diablosport Predator, I have changed my fan settings -- lo speed on at 209, off at 200; hi speed, on at 219, off at 210. These settings seem to be a good compromise between temperature stability and fan life. Thermostat is stock; runs 192 to 196 on the road.
Ernie
FYI, my 02 service manual does have a detailed description of the fan circuit, and at least for the 02s, but I suspect all of them, the fans are low speed and high speed as indicated in the 04 manual, (not one on then two on as was asked way above).
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
