I did when I swaped to a forged lower end.....no injector harness, no spark plugs to allow a high speed spin-up, and coil packs left off....just spin. With the valve cover removed it had oil to the top.
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
So get everything together minus plugs coil packs and injector plugs and turn the key for a few seconds wait a few minutes turn key for a few seconds till oil gets to the top of the motor.. makes sense but doesnt it take quite a few turns to get oil up that far?? seems it takes some people 5 seconds of 800rom idle ??
I left the coil packs in place and simply took out the fuse to the fuel pump. Never had the motor kick over until I put the fuse back in..
