Suggestios for jack with Slammed C5
Old Jan 16, 2006 | 03:43 PM
SynistrC5's Avatar
SynistrC5
Default Suggestios for jack with Slammed C5
Any one got any suggestions for a jack ?I have completely removed the isolator bushing from the frt. ctrl. arm and leaf spring. Any body seen a trick jack that is extremely low to the ground.
Old Jan 16, 2006 | 05:02 PM
JackTsDBG's Avatar
JackTsDBG
Check these from AC Hydraulic:
http://www.asedeals.com/hydraulicjacks2.html
Not cheap.
Old Jan 16, 2006 | 05:09 PM
GTSLN97's Avatar
GTSLN97
drive onto some boards, thats what I do.
Old Jan 16, 2006 | 05:12 PM
FKING1's Avatar
FKING1
Check the clearance between the rocker panel bottoms and the ground. My 00 coupe is slammed and the 3.5" min Harbour Freight jack wont clear. Solution is to get 2 x 6 boards and use to run up on then the jack clears. There is a Mercedes jack some have bought that is a different type and clears very low heights. Do a search and maybe you can find the thread.
Fred
Old Jan 16, 2006 | 06:07 PM
DngrZne's Avatar
DngrZne
I drive my car up onto paving stones first, although a board is probably better since you can cut the edge on an angle to save on the clutch wear.
Chris
Old Jan 16, 2006 | 06:09 PM
AU N EGL's Avatar
AU N EGL
That is what I do. get some 1"x12" x24" boards. Drive the front wheels up on to the boards then you have enough clearance to jack the car up.
Old Jan 16, 2006 | 07:20 PM
SynistrC5's Avatar
SynistrC5
Thanks guys !!!
Old Jan 16, 2006 | 09:24 PM
bennettrp's Avatar
bennettrp
St. Jude Donor '06-'07-'08-'09-'10,'13-'14,'19-'20-'21-'22
Old Jan 16, 2006 | 10:42 PM
SpeedyD's Avatar
SpeedyD
Not cheap.
Wow, you're not kidding!! nice jacks though!! Heavy bastards at 100 lbs!!
Old Jan 16, 2006 | 10:46 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Seems to be what most of us do and that is how I get under mine
Old Jan 17, 2006 | 02:36 AM
blackjack's Avatar
blackjack
I'm with the rest of you. I park on some planks and then use the jack.
To Suggestios for jack with Slammed C5
