C5 + positive battery lead replace
Old Jan 16, 2006 | 11:19 PM
schnaker's Avatar
schnaker
8th Gear
Default C5 + positive battery lead replace
Has anybody replaced the + positive battery wire? It splits two ways, one to the fuse box next to the battery and the other goes straight down and it seems you would have to open up the front wheel well to get to the other connection point. Any help or thoughts are appreciated.
Thanks,
Eric
Old Jan 17, 2006 | 01:11 AM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
The other wire runs directly to the starter.
You will need to drop the H-pipe from the exhaust manifolds to access the starter terminal. If you have LT headers, you'll probably need to remove the pass. side header to get at it.
