Code p0410 and engine running rich...
Old Jan 17, 2006 | 03:54 PM
ex-bmw-man's Avatar
ex-bmw-man
Default Code p0410 and engine running rich...
Well since we bought my wifes vette, it has always smelled really rich when running. I confirmed my suspisions with some dyno pulls and an A/F lower than 10:1 thru the full range. A few months ago the CEL came on, and it is giving me a P0410 code. Could this be caused by bad o2 sensors? I know the 410 is the secondary system looking for a change in the voltage coming back from the sensors, so I'm wondering if the a bad o2 sensor could be causing the 410 code?
I also have an oil sending unit out, so it will probably be a good time to change the valve behind the intake as well while I'm in there.
Jeff
Old Jan 17, 2006 | 03:57 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
I just looked that code up, and it says "Secondary Air Injection System"
Old Jan 17, 2006 | 04:07 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
My car was fine for a year after the LT headers then started throwing p0420 and p0430 codes which are right and left bank cat codes. The rear O2s see the increased flow as an error and throw the light. My tune took care of all that a few weeks back.
Old Jan 17, 2006 | 04:10 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
these are the codes I throw as well caused by the Headers and stock O2's..
the P410 code I think might be something else, maybe with the Air Intake?
Old Jan 17, 2006 | 05:11 PM
dpd's Avatar
dpd
secondary air has nothing to do with it.your fault is for no secondary air action[air pump disconnected,not working,etc.].is the car tuned? if you are running that fat,i would look for either not enough air coming in[clogged/dirty air filter,too much fuel pressure,too much purge,maf not reading right,etc].what are your fuel trims?if you are that fat,you have to be close to turning on the light.it could be o2's,but i would check the obvious first.as far as 410 goes,it looks like you have no secondary air going into either bank[no pump operation,stuck closed shut-off valve,etc]. what are your o2 voltages? are you sure this car is going into closed loop[a bad coolant temp sensor will make you run fat for example].i would need to know more info to help[ie-ltft,stft,o2 voltages,etc.i saw your car is a 98,you have a vent hose coming off the regulator going into the air bridge/accordion,pull off that hose and see if there is fuel in it.
when you dyno'ed it,what did the guy tuning it say?
Old Jan 17, 2006 | 05:52 PM
ex-bmw-man's Avatar
ex-bmw-man
He didn't tune it, but he hooked a tec2 up to it and said it was running really rich, but within spec. He recommended I run the **** out of it more often.
Old Jan 17, 2006 | 06:05 PM
dpd's Avatar
dpd
doesn't make sense.perfect is 0%[14.7:1]with the fuel trims.if you are rich,your front o2 voltages should be anywhere between 700-900mv[the higher the voltage the less oxygen content,the lower the more the oxygen content]if you are running fat[i'll go with the fuel smell]your long/short fuel trims should be minus[pcm pulling fuel out of motor to compensate for rich condition]-25%-+25% turn the cel on.i don't buy the drive it more theory,if it was dyno'ed you simulated the drive it like you stole it theory and the a/f ratio should have straightened out or at least changed.if you ask me,it sounds like you have a problem.JMO
Old Jan 17, 2006 | 06:17 PM
ex-bmw-man's Avatar
ex-bmw-man
I agree, I have a problem. So does the car.....
the air pump runs when teh car is started, and I think I remember it cycling when the car is already warmed up. I'll have to check tonight. I'll probably start with the air valve's and then move on if that doesn't fix it.
Old Jan 17, 2006 | 06:28 PM
dpd's Avatar
dpd
just because the air pump runs,doesn't mean you have air going to the shut-off valve.simple test.start the car cold,the air pump should come on,pll the hose off the check valve on the drivers side,if you feel air blowing on your hand,you may have a bad check valve,clog,etc.if you don't fee any air,look at the line from the pump to the shut-off valve,etc.[you can do the same for the right side].i would be more concerned with the running rich first.
Old Jan 17, 2006 | 06:58 PM
fdxpilot's Avatar
fdxpilot
I had a CEL and that 0410 code a few days ago. I reset the code and it hasn't returned since. I agree that you should check for kinks or obstructions in you AIR system, as that is one of the steps the service manual recommends for this code.
Old Jan 17, 2006 | 09:08 PM
JAvery20's Avatar
JAvery20
Jeff
I just had this code a week ago. Check your hoses, i had one off.
Old Jan 18, 2006 | 04:40 PM
ex-bmw-man's Avatar
ex-bmw-man
sweet, I'll try it tonight.
Jeff
Old Jan 27, 2006 | 11:52 AM
ex-bmw-man's Avatar
ex-bmw-man
OK, wife pulled up in teh driveway last night, car was warmed up to operating temp, but when it was idleing, I could still hear the air pump cycling. Is that normal?
Old Jan 27, 2006 | 12:13 PM
dpd's Avatar
dpd
if the car was still cold,it might,but it should only for about a minute then shut off.if it was running rich,it's because it doesn't shut off and the front o2's are seeing so much air,the pcm compensates for the extra air by fattening the mixture.more than likely the pump relay is stuck
Old Jan 30, 2006 | 11:41 AM
ex-bmw-man's Avatar
ex-bmw-man
Is teh pump relay sticking a common problem?
Is it in the fuse panel under the pass kick panel?
Old Jan 30, 2006 | 11:45 AM
dpd's Avatar
dpd
it's happened before.i think it's in the underhood fuse block.it should be marked.
To Code p0410 and engine running rich...
