Is it as simple as unbolting the LS1 intake and bolting on the LS6? The throttle bodies aren't any different are they? What about the valley cover, coolant lines, etc? Thanks.
You have to get a new front coolant line and 2 plugs for the back,It should come with the LS6 intake.You will see when you take off the LS1 intake.I just changed mine,its pretty easy.Go to www.LS1howto.com .They have pictures and how to change over.
In the old days we ground off a path in the webbing under the LS6 manifold and ran the LS1 cooling pipes. It works fine but you will probably have the new tubing setup?
I bought mine from Corvette Garage and it came with the coolant pipe and two plugs.
When you remove the intake you will see a very small vacuum line on the rear of the manifold near the MAP sensor. While it's off, extend the line 6 inches or so. It will make life much easier going back on.
