Baer 6 piston brake Kit
Old Jan 18, 2006 | 11:45 AM
1coolC2's Avatar
1coolC2
Default Baer 6 piston brake Kit
Anyone out there running the Baer 14" Eradispeed with the 6 pistion caliper kit. It requires 18" wheels but I want to know if factory 18's will clear the rotor/caliper with out a wheel spacer.
Old Jan 18, 2006 | 12:51 PM
JEEP/C5's Avatar
JEEP/C5
Sound like your talking about the rear brakes. I have the Eradispeed 14 inch with stock calper. I would think the 6 piston would have a wider sweep area that the stock does and the 14 inch. I have only has a little area not being used by the stock calpers (1/4 inch?). I wonder if the 14 inch rear is different than mine - if its not it may not work for the big calper. Just a thought.
Old Jan 18, 2006 | 01:09 PM
AU N EGL's Avatar
AU N EGL
the 6-pistion calipers and two piece rotors need a larger off set then the stock wheels. No the rear wheel could not be used up front.
To Baer 6 piston brake Kit
