From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
Originally Posted by DRIVER456
I just installed LG street series headers w/high flow cats.
I also have LG's and they do not cross. When I got my car tuned he wanted to make sure that we DID NOT cross them because he said it would run like crap!
If you have LG headers, you only have provisions for the front (pre-cat) sensors, and although you physically use the original rear sensors, realize they are now taking on the role of the front sensors, and you do not cross those.
you DIDN'T say you put HEADERS on it!!!! if you are running lg's with 4 sensors[2 front, 2 rear],you hook it back up JUST LIKE STOCK[rears cross].the SENSORS in the COLLECTORS go LEFT to LEFT,RIGHT to RIGHT,the SENSORS in the X-PIPE cross LEFT to RIGHT,RIGHT to LEFT
OK whats the difference if you have headers or not,All I ask if the Rear O2 sensors cross or not.I'm running all 4 sensors.
Although not on the car, you can easily see how and where the wires cross where they meet the sensors, due to the size contraints of the tunnel, it's really the only possible way to run these wires without them touching the pipes.
If your LG system uses 4 sensors....the wiring for the front 2 do NOT cross, but the rear ones do, and the orientation of the sensors, and the wiring should look like the above.
I know the front is right to right ect. ect. So what your saying is the right O2 sensor going to the rear of the car that is plugged in at the right side of of the car(passenger side) which is about right below the fire wall goes to the left side(drivers side) rear O2 bung.Yes or no is all I want to know did that make sense
I'm saying the wire of the rear sensor physically screwed into the left pipe runs up along the right side of the tunnel, and connects on the right side of the engine.
The wires for the sensor physically screwed into the right pipe euns up the left side of the tunnel, and connects to the harness on the left side of the engine.
