M6 Trans Temp using Oil Temp???
Old Jan 18, 2006 | 11:00 PM
Bob25thTA's Avatar
Bob25thTA
Default M6 Trans Temp using Oil Temp???
Rather than buy a seperate guage I was thinking about using a engine oil temp sensor and a switch to toggle between engine oil temp and transmission temp. This would display the reading on the DIC as oil temp, is this totaly absurd or a possibility???
Old Jan 18, 2006 | 11:04 PM
turboc5's Avatar
turboc5
In europe they han a manual trans temp sensor. I believe it reads out on the DIC. I too would like to know if any body has done this conversion?
Old Jan 18, 2006 | 11:31 PM
ryanbush's Avatar
ryanbush
My a4 has a trans temp guage, I'm assuming the mn6s are diffrent?
Old Jan 19, 2006 | 12:43 AM
SpeedyZ's Avatar
SpeedyZ
I think that is an excellent idea. I don't see any reason it wouldn't work and it should be easy to do!
Old Jan 19, 2006 | 04:51 AM
mathia's Avatar
mathia
That is a clever idea. You'd have to have a temp sender for the trans fluid that was calibrated the same as the oil temp sender. Perhaps an adaptor could be made to put the factory oil temp sender into the trans fill plug hole.
To M6 Trans Temp using Oil Temp???
