402 stroker
Old Jan 19, 2006 | 08:44 PM
108C6's Avatar
108C6
Default 402 stroker
anyone running a slp 402 my 98 needs a new eng. thinking about the 402 my old motor had 426 rwhp just wondering if it is worth the money?
Old Jan 19, 2006 | 08:51 PM
NXTFAZE's Avatar
NXTFAZE
Friend of mine put one in....
520 rwhp/ 490 tq NA.... and has a 150 shot on top.
Old Jan 19, 2006 | 11:26 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Hopefully mine will be ready tomorrow.
Old Jan 19, 2006 | 11:54 PM
tnsyty's Avatar
tnsyty
i have a 98 with 78k miles. How many miles did yours have? Did it break? details? I want more cubes in mine, I say YES to the 402. What mods did you have on the old engine?
Old Jan 20, 2006 | 12:00 AM
jhong321's Avatar
jhong321
I have a 402 in my frc and i love the the tq. (489 rwtq) I got mine from SDPC I think in the long run you will be happier with SDPC instead of SLP. You might want to check out ls1tech.com to find out more info on the motor and the builders
Old Jan 20, 2006 | 12:22 AM
Cajundude's Avatar
Cajundude
Sorry, just noticed the "slp". My motor is actually coming from MTI with Lunati internals.
Old Jan 20, 2006 | 01:25 AM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
made in USA.
Eagle cranks made in China.
Old Jan 20, 2006 | 07:03 AM
see5's Avatar
see5
http://www.ls1tech.com/forums/showthread.php?t=438868
Old Jan 20, 2006 | 08:28 AM
IFLUBYU's Avatar
IFLUBYU
Get a set of ETP or AFR 225s and 90mm im/tb setup to go with the shortblock. Man, if I only had the dough...
Old Jan 20, 2006 | 08:39 AM
Mikelly's Avatar
Mikelly
Man that's sickening to read that thread... Something's up there!
mike
Old Jan 20, 2006 | 10:10 AM
bluewire's Avatar
bluewire
There have been many problems reported with the slp motors, I would stay clear of them. I would look at the one's being offered by TSP or SDPC.
Old Jan 20, 2006 | 11:11 AM
Mikelly's Avatar
Mikelly
SLP just responded... This should get interesting!
Mike
Old Jan 20, 2006 | 11:27 AM
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
That motor looks to me like it has been rattleing. Too much timming, not enough fuel. A good tune on a motor with even cast pistons would last longer. Just because one guy bought a motor and the pistons came apart in every hole doesn't mean it's a bad piston design. I have no ties to SLP or Ross pistons, but I think they need some help about now.
Old Jan 20, 2006 | 03:50 PM
Mikelly's Avatar
Mikelly
As I posted in the thread over there, something doesn't make sense. He didn't use the old intake, so there is no chance previous junk from the old motor was the culprit.
I don't see how anyone can point the finger anywhere at this point. Could be a bad shortblock/ pistons, could be a bad assembly at the shop for the long block, or could be the tune.
Sounds to me like the guy just wants to vent about the situation, and he's getting a little support from the installer, so he's not mad at them. SLP needs to COMMUNICATE better in the beginning to stave off little issues like this...
Mike
Old Jan 20, 2006 | 04:13 PM
edensknight's Avatar
edensknight
Old Jan 20, 2006 | 08:04 PM
108C6's Avatar
108C6
car has around 38000 had afr heads valve spring seats started to come apart where the spring sit in the head pulled them was cleaning head bolt threads foundposs. crack or hole in 4th hole back on top driver side going to get a bore scope and see how bad car ran very good til the head problem it dynoed 426 rwhp lasted for about 1500 miles that is why i am looking at a 402
Old Jan 20, 2006 | 08:07 PM
108C6's Avatar
108C6
car also had a custom grind joe overton cam
To 402 stroker
Old Jan 20, 2006 | 08:44 PM
magredZ51's Avatar
magredZ51
I would go bigger. If moneys not an issue go for a LS2 based stroker.
If on a budget than at least an LS2 shortblock!
Old Jan 20, 2006 | 09:36 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
This will be home built - see sig
Old Jan 21, 2006 | 12:19 AM
Shane_S's Avatar
Shane_S
I was considering the SLP 402 as an option but i'm not sure now. Think i'll wear out my stocker first.
Shane
