4" airbridge custom pics...
Old Jan 19, 2006 | 10:38 PM
Phil97SVT's Avatar
Phil97SVT
Default 4" airbridge custom pics...
With my new motor I decided to sell all of the air bridges I had and make one from scratch, took me about 15 minutes with a bandsaw and my tig welder. End result is good but can always be better. Enjoy!
Old Jan 19, 2006 | 10:54 PM
black98c5's Avatar
black98c5
Looks really clean. what kind of gains are expected to be had with this custom setup.
Old Jan 19, 2006 | 10:59 PM
Phil97SVT's Avatar
Phil97SVT
Don't really know, just know that the intake is only as good as its restriction or restrictor plate. No MAF or small air bridge on this motor.
Phil
Old Jan 19, 2006 | 11:07 PM
captainpooby's Avatar
captainpooby
Old Jan 19, 2006 | 11:12 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Looks great
Old Jan 19, 2006 | 11:25 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Lookin' good. Did you use 4" semi exhaust pipe?
Old Jan 19, 2006 | 11:32 PM
Phil97SVT's Avatar
Phil97SVT
Thanks guys, actually a friend of mine who I used to race DSM's with turned me onto a company that sells aluminum 4" mandrel bend U bends. We purchased 2 u-bends and 12" of pipe. They are for intercoolers and turbo cold side pipes.
Old Jan 20, 2006 | 04:04 AM
NocarbutaVetteforme's Avatar
NocarbutaVetteforme
Damn I bet that flows well! Very nice work. And you are right, your flow is only as good as the most restricted point.
Old Jan 20, 2006 | 06:23 AM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Looks good Phil
Old Jan 20, 2006 | 06:48 AM
WKMCD's Avatar
WKMCD
Sweet setup. Had to go ahead and polish it didn't you.
Old Jan 20, 2006 | 08:14 AM
Phil97SVT's Avatar
Phil97SVT
Actually, I just hit it real quick with the buffer. Its gonna polish up nice!
Phil
Old Jan 20, 2006 | 09:33 AM
mqqn's Avatar
mqqn
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Donor '03-'04-'05-'06-'07-'11
Hi Phil -
Nice!
Will the hood close down ok, or would a stock hood bulge up in the middle using that large an air bridge?
Nice work and thanks for the great idea!
best regards -
mqqn
Old Jan 20, 2006 | 09:38 AM
Phil97SVT's Avatar
Phil97SVT
Originally Posted by mqqn
Hi Phil -
Nice!
best regards -
mqqn
When we mocked it up, we used a string to mark the height of the factory bridge. This setup is the same height as the factory. We are going to lower the radiator slightly to make sure it fits like a glove.
Phil
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
I'm assuming the hood closes normally... so w/o a MAF at all is it a speed density tune? In layman's terms how does the engine monitor air flow and adjust fuel accordingly... is there a different sensor somewhere?
Please let us know what the NA dyno numbers are.
Old Jan 20, 2006 | 09:39 AM
Phil97SVT's Avatar
Phil97SVT
Map sensor + IAT + VE table will be used for fueling. Hood will close just like it did before.
Old Jan 20, 2006 | 09:40 AM
mqqn's Avatar
mqqn
Cruise-In V Veteran
Phil
Thank you Phil!
Best Regards -
mqqn
Old Jan 20, 2006 | 10:04 AM
HP_Addict's Avatar
HP_Addict
If this will work with the stock hood, then it will be a great alternative for the guys running high boost. It looks a lot better than the BBK unit and should flow better as well.
However I thought Phil was running a cowl hood, so he has more clearance. I wonder if it is possible to just lower the radiator some without laying it over.
Great work!
To 4" airbridge custom pics...
Old Jan 20, 2006 | 10:33 AM
Phil97SVT's Avatar
Phil97SVT
Great work!
Chris,
No cowl hood here, just a lowered radiator.
Phil
Old Jan 20, 2006 | 11:52 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
cool
Old Jan 20, 2006 | 12:33 PM
Sportsdude's Avatar
Sportsdude
That looks nice
