2001 Tire Pressure Sensor
Old Jan 20, 2006 | 01:38 PM
KyMagRed's Avatar
KyMagRed
Default 2001 Tire Pressure Sensor
My Right Front read out says 5psi, but it checks out at 30psi. My Left Front was low and after adding some it reads 29psi. Two things, I had new tires installed in August so the front wheels may have been swapped. And I think they have. So will the reprogramming fix this sensor? Or do I need to replace the sensor?
Old Jan 20, 2006 | 02:40 PM
ROCKnROLL's Avatar
ROCKnROLL
Veteran
Click on this link for instructions on reprogramming your tire pressure sensors and you'll be good to go.
https://www.corvetteforum.com/techti...D=77&TopicID=1
