Differential lube
Old Jan 21, 2006 | 01:17 PM
Bubbletop409's Avatar
Bubbletop409
Default Differential lube
New C-5 owner with a question. Since the 6speed trans and differential are mated to each other, do they share the same lube, or are they sealed from each other and use different types of lube, thanks, Larry.
Old Jan 21, 2006 | 01:47 PM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default Rear/Trans Lubes
Trans/Rear lubes are different. They do not share a common lune supply.
I'm changing my rear out and plan on using Royal Purple in the trans and rear.
Bob K.
Old Jan 21, 2006 | 02:46 PM
DADEO1's Avatar
DADEO1
Default Lube
They are seperate.
Use the Royal Purple. Great stuff, solved some problems for me just by changing the fluid to RP.
The Vette runs wonderful with that stuff.
Old Jan 21, 2006 | 09:25 PM
Bubbletop409
So what is the suggested Royal Purple lube for the diff.? Does is need the posi additives of the older diff's.? Thanks, Larry.
Old Jan 21, 2006 | 10:41 PM
rws.1's Avatar
rws.1
The six speed box (Tremec) takes Dexron III ATF
Mobil 1 or royal Purple or Red Line are popular
The rear diff takes 75W90 synthetic gear oil.
Again pick your favorite brand. I add the GM posi fluid regardless of the brand of Gear oil I use.
Old Jan 22, 2006 | 12:07 AM
Bubbletop409
THANKS rws1. I agree with the GM posi fluid additive. I allready have RP 75-90 on hand, so I'm set like a Rolex, Larry.
Old Jan 22, 2006 | 11:38 AM
Alex D's Avatar
Alex D
I always play it safe here. I only use the factory fluid with additive and change it every 15,000 miles since it only takes about 5 minutes to change with the car sitting on its own wheels in the garage.
One problem wiht the factory fill is the fact that a lot of the diffs are overfilled by 5 oz. or more. Mine was leaking out of the breather on top, so I checked it warm and on a level surface. Drained 5 oz. out before it was level with the bottom of the hole. I wonder if overfilling also has an impact on the actual leaks developing on the radila seal and case gasket??
To Differential lube
