FLP headers and burned plug wires....
Old Jan 21, 2006 | 03:07 PM
0rion's Avatar
0rion
Default FLP headers and burned plug wires....
A buddy of mine has FLP headers on his 98 and has a bad problem with the headers burning the plug wires. #7 is the worst. This is even through kevlar sleeves. Anyone else have this problem and find a fix? I think some 45 degree boots would help out but he hasn't tried that yet.
Old Jan 21, 2006 | 08:35 PM
Jeffs FRC's Avatar
Jeffs FRC
I've got FLP's on my 00 and dont have a problem burning wires. What wires is your buddy running? My stockers dont seem to have a problem.
Jeff
Old Jan 21, 2006 | 09:07 PM
BAD_TCR's Avatar
BAD_TCR
FLP's here and I dont have a problem. However, the number 7 wire does touch the header. I am hoping your LTs are coated though, right?
Old Jan 21, 2006 | 09:55 PM
LoneStarFRC's Avatar
LoneStarFRC
Magnacore KV85's with 45 degree plug boots.
Old Jan 21, 2006 | 11:10 PM
0rion's Avatar
0rion
Where did you get these at?
He's running coated FLP's and MSD wires. No matter how you spin the wire it still touches #7 enough to burn it and it eventually cracks.
Old Jan 21, 2006 | 11:30 PM
JerriVette's Avatar
JerriVette
I've heard the stock wires with stock heat shield boots are the best bet against burning wires..
Old Jan 24, 2006 | 07:20 PM
LoneStarFRC
Thunder Racing. There are two versions; one with conventional straight boots and the other with 45 degree boots. Just specify when ordering. HTH
BTW, I'm running Kook's headers but I don't know that the bend in the pipe of #7 is any different than FLP's. The boots on both ends of the KV85's grip very well and allows you to position the wire for max clearance. As with any wire set, just be sure to "burp" the coil boots when installing to prevent any shifting.
Old Jan 25, 2006 | 01:04 AM
Dirty Howie's Avatar
Dirty Howie
Which one is #7......I would like to check the clearance on my Kooks
Also what the hell is "burping" mean??????
DH
Old Jan 25, 2006 | 08:18 PM
LoneStarFRC
DH
Number seven is driver's side next to the firewall.
The boots on many brands of wires have such a good fit on the coils that, when installing, they may have a tendency to creep back off due to air trapped inside. If you use a silicone dialectric grease it tends to aggravate this.
To "burp" them, hold the boot on good and tight, and insert a small screwdriver into the boot. It allows the air to escape and the boot is secure. HTH
Old Jan 25, 2006 | 08:27 PM
7LitreC5's Avatar
7LitreC5
I had my FLPs on for 3-1/2 years and never had any problems. I was and still am running the stock plug wires.
Old Jan 25, 2006 | 09:37 PM
Dirty Howie
I was getting some strange noises from under the hood. Then I had plugs and wires changed and the noise went away. I suspect I was getting some arcing. So now I want to make sure the wires are in good shape and I guess BURPED
DH
Old Jan 25, 2006 | 10:03 PM
LoneStarFRC
DH
Remember: A Burped Boot is a Happy Boot.
To FLP headers and burned plug wires....
