Posted this question in 'c5 general' might be the wrong place...
My '99 has chips and a few scratches on the nose. I want to remove the front,(section containing the parking lights etc.) to repaint it. Can anyone tell me what the difficulty level is and disassembly tips you might have?
1- Remove the front license plate
2- Remove the plastic headed screws attaching the fascia license plate opening to the absorber. (Behind the license plate).
3- Raise the vehicle.
4- Remove air deflector and the left and right outer valance. (spoiler)
5- Remove the bolts attaching the fascia to the skid bar.
6- Remove the bolts attaching the fascia to the radiator support
7- Remove the fascia lower close out panel. (The same one we need to remove to change the bulbs).
8- Remove the bolts attaching the wheelhouse panel to the fascia.
9- Disconnect the fascia harness connector. (for the drl, parking, etc.) Located on the passenger side.
10- Remove the nuts from the fender reinforcement studs. Located at the upper corners.
11- Disconnect the front brake caliper cooling ducts from the fascia.
12- Lower the vehicle
13- Remove the push-pins attaching the fascia upper flange to the fascia retainer. Located where we put the hoodseal.
14- Remove the fascia.
Step #1 -- What License plate? There's a place for a plate?
Unfortunately in Massachusetts They like stopping vettes with no front plate displayed. I put it on...there is NO way to make that thing #$&** ^$# look good!!
I hear you. In New York you need one as well so I am pushing my luck. I keep the plate close by, behind me, so I can place it on the dash, as a minimum, if I ever get stopped.
