Arp Head Studs
Old Jan 23, 2006 | 12:11 AM
turboc5's Avatar
turboc5
Default Arp Head Studs
Does arp make stainless steel head studs for a 2000 ls1? Ive seen them on some engines, just can't find them for ls1's. Not to sound "ricy" but I don't want the chromolly ones to rust. The ss would look better and if they both seal, whats the diffrence.
Old Jan 23, 2006 | 08:40 AM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
After working on food processing machinery for the past 10 yrs. Stainless and aluminum don't mix well sometimes. I've had the standart head studs in for almost 2 years now, without a rusting issue, and I actually wash the engine bay
Old Jan 23, 2006 | 10:39 AM
Mikelly's Avatar
Mikelly
Also, The price was pretty "out there" when I priced head studs for out buildup. I ended up with the ARP Head Bolt kit. Still cost a pretty $.01, but still!
Mike
Old Jan 23, 2006 | 11:15 AM
cjs27410's Avatar
cjs27410
Stainless only goes to grade 5 those arp bolts are at least a grade 8.
Old Jan 23, 2006 | 12:52 PM
INTHERED's Avatar
INTHERED
You definately do not want SS head bolts. Satinless steel does not
have the proper strech characteristics for the head bolt application.
Go to www.arp-bolts.com and look at their catalog I don't think that
they even offer SS head bolts.
INTHERED
Old Jan 23, 2006 | 06:26 PM
turboc5's Avatar
turboc5
Very good points! I didn't think about dissimular metals. The stainless ones were probly just for show. I will go with the chomolly ones. Thanks
Old Jan 23, 2006 | 06:38 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
If you plan on future teardowns...go with the studs.
Old Jan 23, 2006 | 09:36 PM
IFLUBYU's Avatar
IFLUBYU
For show? If you are looking at your head bolts more than once a year, I'd say you have more problems than how pretty they are!
Unless they are making transparent aluminum valve covers, now there's an idea!
Old Jan 24, 2006 | 12:03 AM
turboc5's Avatar
turboc5
I'm defandly not that worried about the way the engine looks, I've seen ss head bolts before on sbc's and was just wondering if they are available. I just dont want any rusty nuts
Old Jan 24, 2006 | 06:22 AM
vettenuts's Avatar
vettenuts
The black oxide finish should keep the rust at bay, and the use of their lube during installation should protect the finish during the tightening process. I have ordered their 12 point stud kit for my Dart head installation I am planning for this spring.
To Arp Head Studs
