Oil Pressure
Old Jan 23, 2006 | 02:24 PM
BosqueVette98's Avatar
BosqueVette98
Default Oil Pressure
I noticed the oil pressure gage is pegged at 80psi and shows 129psi on the information center. It started doing this the other day after I drove off without letting the car warm up. It even reports those numbers with the car turned off but the key in the on position.
Does anyone know what might be happening?
It's a 1998 model...
Thanks for any help y'all can give!
Rich
Old Jan 23, 2006 | 02:33 PM
TSDuke's Avatar
TSDuke
Bad oil pressure sending unit. You have to remove the intake manifold to replace it. It's in the area below.
http://forums.corvetteforum.com/show...5&forum_id=103
Old Jan 23, 2006 | 02:43 PM
BosqueVette98
Thanks! Sounds like an expensive repair. It won't hurt the car to drive it like that will it?
Old Jan 23, 2006 | 03:47 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Won't hurt anything, and it's a cheap repair if you can turn a wrench and follow directions
Old Jan 23, 2006 | 04:26 PM
BosqueVette98
Thanks for your reply, I was really afraid I was hurting the engine...
Rich
Old Jan 23, 2006 | 04:33 PM
Markham's Avatar
Markham
Default Diagnosis
To be sure it is the Oil Pressure sensor, turn the car on to the ignition position without starting the engine. If the gauge creeps up, it is the sender.
I hope this helps.
Old Jan 23, 2006 | 04:47 PM
SpeedyD's Avatar
SpeedyD
Well that won't hurt the car, but if you lose oil pressure and don't know it, that will! Good luck!
Old Jan 23, 2006 | 04:56 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Very very very few cases of that happening on a stock block if ever... the design of the oil pump pretty much can't fail, only wear out and lose pressure over time.
Anyways, I've been without mine for over a year now--but it's not a bad idea to fix, as I'll be doing when I do my heads/cam/headers in the next few weeks
Old Jan 23, 2006 | 05:06 PM
SpeedyD's Avatar
SpeedyD
I've gone without gauges on some of my other cars, but I guess with my luck I would play it safe with my vette. If it wasn't for bad luck, I'd have none at all!! But yeah you're right, the chance of it going are very slim!
Old Jan 23, 2006 | 06:55 PM
BosqueVette98
I hope this helps.
That is exactly what it is doing... Thanks!
Old Jan 25, 2006 | 05:31 PM
ThePizzaC5's Avatar
ThePizzaC5
Might as well order the LS6 intake manifold while you're in there.
Old Feb 8, 2006 | 12:28 PM
BosqueVette98
For the people that have replaced the oil pressure sending unit themselves, by partially sliding the intake forward... What did y'all do about the intake gaskets? Did they not need to be replaced?
I'm fixin' to attempt this repair myself and was just curious...
Thanks for any advice!
Rich
Old Feb 8, 2006 | 12:32 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
they're very reusable...it wont hurt them. couldn't hurt to replace them but not necessary
Old Feb 8, 2006 | 12:56 PM
BosqueVette98
Great, thanks!
Old Feb 8, 2006 | 07:05 PM
Y2YELLOWCOUPE's Avatar
Y2YELLOWCOUPE
mine just died and went to the 80 psi gods
To Oil Pressure
