Which Clutch????
Old Jan 23, 2006 | 10:12 PM
FRCBobby's Avatar
0FRCBobby
Former Vendor
Default Which Clutch????
I got my A&A kit installed and now the clutch is starting to slip pretty badly.
I have searched and read about several clutches but just can't make a definite decision on which one.
Right now I like the Textralia, Spec, Cartek.
Any others I should consider and which one should I choose.
Old Jan 23, 2006 | 11:33 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Andy recommended the RPS clutch to me and I have 2k on my car and it is holding up to my HP 731 and 645 TQ levels. I bought the clutch and flywheel and upgraded to the Z06 master and slave at the same time. This clutch is stiff at first and then not much stiffer than a Z06 clutch
Old Jan 23, 2006 | 11:42 PM
Tsab's Avatar
Tsab
Cartek Clutch is a pretty durable unit. I've had mine now for well over 75 drag passes. I'm amazed about how much abuse its taken, Its still hanging in there.
Old Jan 23, 2006 | 11:55 PM
Pakisho's Avatar
Pakisho
Ive heard good things about the cartek, no personal experience.
I had a spec hybrid. Hated it.
Current: rps. Love the hell out of it.
Old Jan 24, 2006 | 05:48 AM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I was in the same boat as you. I spoke with a lot of different people and narrowed it down to RPS and Cartek. I bought the Cartek. Can't comment on it because I am in the middle of the install right now. Also going with a Fidanza billet steel flywheel.
Old Jan 24, 2006 | 07:31 AM
Mr. Jones's Avatar
Mr. Jones
I have the RPS setup, still breaking it in.
similar feel to stock, a little stiffer and a very noticable lockup.
the alum. flywheel makes downshifts/rpm matching a little easyier
nice setup for the money
Old Jan 24, 2006 | 08:22 AM
Mikelly's Avatar
Mikelly
I've got the Exidy Hyper stage 3. It was stiffer at first, but has started to break in and isn't as bad. I'm not making the power you're throwing down, but just with a heads and cam I overcame the new Z06 clutch we had installed with the new motor within 2K miles. They claim 650#ft. torque on it, but I don't know how much that is advertising.
I've heard real good things about the new LS7 clutch... Stock feel, great engagement, and super strong!
Mike
Old Jan 24, 2006 | 10:28 AM
J-Rod's Avatar
J-Rod
Textralia. I have one, and you'll love it...
Old Jan 24, 2006 | 06:22 PM
108C6's Avatar
108C6
I put textralia in mine.when i get it running can drive it and see if u like it
Old Jan 25, 2006 | 11:39 AM
FRCBobby's Avatar
0FRCBobby
Former Vendor
Thanks alot man, not sure if I will get to drive yours before I order though, mine is slipping pretty bad and I will need one soon. Thanks for the offer though.
How does it feel compared to stock and which flywheel did you go with?
To Which Clutch????
