LS6 heads
Old Jan 24, 2006 | 08:59 AM
2kvert's Avatar
2kvert
Default LS6 heads
About how much performance will I gain with LS6 heads on an LS1 engine?
Old Jan 24, 2006 | 11:50 AM
vettenuts's Avatar
vettenuts
All things remaining the same, I would guess 10-15 HP.
Old Jan 24, 2006 | 11:55 AM
M_T_0's Avatar
M_T_0
ls6 cam, heads and intake will get you about 50hp
Old Feb 1, 2006 | 06:29 PM
1996man's Avatar
1996man
i found it interesting MTI claims they can port and polish LS6 heads to flow (at stage III) around 330+cfm intake. this seems really well but i wonder how much hp you are planning on making if there are aftermarket companies that make heads that flow more than that.
Old Feb 6, 2006 | 04:17 PM
1996man's Avatar
1996man
are there aftermarket companies that make heads that flow over 330cfm for the LS block?
Old Feb 6, 2006 | 04:47 PM
mdhmi's Avatar
mdhmi
330? I don't buy it. LS6 heads can make good power, but usually by the time you get the Stage III porting and upgraded valve train you could have just bought AFR's. JMHO
Mark
Old Feb 6, 2006 | 09:10 PM
1996man's Avatar
1996man
Mark
how much flow do the top of the line AFRs
have for the LS motors?
To LS6 heads
