Another A/C question
Old Aug 6, 2001 | 10:33 PM
RPO_Z06's Avatar
RPO_Z06
Cruise-In III Veteran
St. Jude Contributor
Default Another A/C question
I have a strange thing going on with my A/C.
When I turn it on it's cool but not cold, however if I pull in to shade it gets ICE cold in about 2 seconds.
I noticed this today when I was driving home from work it was cool enough to keep me from melting and the second I pulled in the garage it was cold.
To test it I backed it out and BAM wamed up in 2 seconds, so I pulled back in and it was cold again. :confused:
I figure it must be the sun load sensor on the top of the dash but I'm not sure. :crazy:
Any help would be appreciated.
Old Aug 8, 2001 | 12:14 AM
RPO_Z06's Avatar
RPO_Z06
Default Re: Another A/C question (White_98)
A new twist to the A/C, Today the system worked the same as above except that it would get colder when I stoped at lights, but not everytime..
This thing making me. :crazy:
Old Aug 8, 2001 | 12:48 AM
lyonsh's Avatar
lyonsh
Ok, first understand I'm not an EXPERT on A/C. I've fixed a few, I've taken the class at the community college, but I'm shadetree only.
Having said that: the computer that controls your A/C receives a number of inputs (ambient temp, etc.), including, as you point out, the "sun sensor." When it sees lots of light, the computer says "ok, probably warm in there with the light, not unusual, just keep turning at the normal rate." Somehow, it sounds like when part of the light gets blocked, your computer is combining the light condition with something like ambient temperature, thinking something is abnormal, and going into "panic mode" = max cooling.
In short, your computer is neurotic, either because a sensor is sending it wierd signals or it has an internal problem. Time to take it to someone with the right scanner to figure out what the problem is: the good news is that with modern OBD, they should be able to figure out the problem relatively easily.
Of course, I could be completely wrong - as I said, I'm not an expert.
Good luck with it :cheers:
Old Aug 8, 2001 | 12:57 AM
RPO_Z06's Avatar
RPO_Z06
Default Re: Another A/C question (lyonsh)
The ambient temperature sensor hadn't crossed my mind..
Thanks for the heads up..
To Another A/C question
