Ls 1
Old Jan 24, 2006 | 06:41 PM
Gary French's Avatar
Gary French
Default Ls 1
I have an 03 vert, I was told I have an LS 6 intake, Is that correct ?
Old Jan 24, 2006 | 06:42 PM
dpd's Avatar
dpd
correct
Old Jan 24, 2006 | 06:54 PM
NSTG8R's Avatar
NSTG8R
not only that .. it's got an ls6 block too.
Old Jan 24, 2006 | 06:59 PM
RichieRichZ06's Avatar
RichieRichZ06
From: Supporting the Corvette Community at Abel Chevrolet in Rio Vista, CA 707-374-6317 Ext.123
St. Jude Donor '08
2001 and after are the ls6. Even the F bodies got the ls6 manifold.
Old Jan 24, 2006 | 07:10 PM
Nithros's Avatar
Nithros
St. Jude Partner since 89
St. Jude Donor '09
Not trying to hijack but are you sure about that?
Old Jan 24, 2006 | 07:32 PM
dpd's Avatar
dpd
yea,i'm pretty sure he's right.one of the differences between the blocks is the way it ventilated[crankcase ventilation].it helped eliminate alot of the oil burning,though i think the internals may be different[rods/pistons/etc],i know the cam/heads/valves are different.
Old Jan 24, 2006 | 07:39 PM
NSTG8R's Avatar
NSTG8R
you think i would post information if it wasnt true?
well regardless they did come with the ls6 block just not the heads or cam.
Old Jan 25, 2006 | 12:10 AM
Shane_S's Avatar
Shane_S
/Yep, which means for $700 or so not including labor you can have the exact engine the C5 Z06 has Just get some gently used #243 casting heads and Z06 cam from somebody that went with aftermarket heads/cam and you'll make ~345rwhp and it'll idle like it's stock. Lol well basically because It will be. Just stock for a Z06
Shane
To Ls 1
