got electrical issues?
Old Jan 25, 2006 | 01:46 AM
gamisou's Avatar
gamisou
Default got electrical issues?
Just wanted to let anyone with RFA module and BCM problems to check this out. I have had electrical bugs occuring occasionally from keyless entry not working, security light going in for no reason while driving and other strange things. The wiring harness connecting to the BCM on the passenger floor has 3 plugs for the BCM itself and 2 other connections. The second 2 have a plug on them that bridges all the wires in each bundle together. Mine were completely covered in corrosion. Took them apart soldered all the wires in each bundles together, Keyless works no more strange trouble codes so far. Post back if anybody finds the same problem. Hope this could help someone else.
Steve
Old Jan 25, 2006 | 02:29 AM
Cscokd's Avatar
Cscokd
any ideas what caused all the corrosion? water leak? A/C condensation?
