Sealant on Waterpump?
Old Jan 25, 2006 | 02:39 PM
kman0066's Avatar
kman0066
Default Sealant on Waterpump?
I took the waterpump off my 98 and the thing was pretty much glued onto the block with the paper gaskets. I got paper and metal gaskets with my gasket kit. Can I use the metal ones or do I need to use the paper ones. Also, what type of sealant do I use with the paper gaskets, just RTV or what?
Old Jan 25, 2006 | 05:47 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
How was it getting the old gasket off? I have the paper ones also,when I put my water pump back on,I'm just going to spray alittle sealant on them to just hold them in place.
Old Jan 25, 2006 | 07:30 PM
vette747's Avatar
vette747
That was a pita to remove the original paper gasket. Make sure you reinstall with the metal gasket. I ordered a set for a 01 from GM. I’m pretty sure that no sealant is required for the metal & ‘O’ ring gasket type. Just to be on the safe side, I added some standard sealant from local auto part store.
Old Jan 25, 2006 | 07:46 PM
DRIVER456's Avatar
DRIVER456
St. Jude Donor '07
I take it the metal ones are better?,I took off ,Lets say I scraped for awhile the old paper ones off .Are there any problems putting new paper gaskets back?............Paul
Old Jan 25, 2006 | 09:29 PM
vette747's Avatar
vette747
No problem putting new paper gasket. I put the metal because I did not want to scrape the paper gasket for 90 minutes next time I have to remove the water pump. The metal gasket came standard starting I think in 99.
Old Jan 25, 2006 | 09:33 PM
LoneStarFRC's Avatar
LoneStarFRC
The aluminum gaskets have pre-molded silicone beads around each hole and don't require any sealant. Just be sure the sealing surface is clean and smooth after removing the old paper gaskets and everything should be fine.
To Sealant on Waterpump?
