Light problem... headlights won't go down
Old Jan 25, 2006 | 04:56 PM
REDLYNER's Avatar
REDLYNER
Default Light problem... headlights won't go down
I just replaced my daytime running lights (blinkers) and now my headlights won't go down.
Any ideas? Never had this problem before. All of the lights work, they just won't close.
Help!
Old Jan 25, 2006 | 06:44 PM
turboc5's Avatar
turboc5
Are your sure they are the correct bulbs? The headlights not going down are a indicator of a bulb out.
Old Oct 5, 2017 | 01:57 PM
Choptop's Avatar
Choptop
Dredging this up.
I'm having the same problem. just replaced turn signal bulbs (the exact some kind that came out and they work)... and now the headlights wont go down.
any thoughts?
will they stay up if my fog light bulbs are burnt out?
Old Oct 5, 2017 | 02:51 PM
Choptop's Avatar
Choptop
Found the problem.
When changing the turn signal bulbs one had broken glass. In the process of pulling it out, the burnt out filament briefly shorted out... blew the fuse on the circuit (not for the drl or turn signals oddly enough, those both worked after install, but for the tail lights)... making the headlight module think there was bulb out and keeping them up.
Replace the tail light fuse (located in the passenger footwell) and bingo... headlights go down. Tail lights AND fog lights work (they appear to be on the same fuse).
sooooooooo... what would have stopped this? Bringing the headlights up and then disconnecting the battery before changing the turn signals. No juice, no short, no burnt out fuse.
Old Oct 7, 2017 | 02:59 PM
GCG's Avatar
GCG
Originally Posted by Choptop
Found the problem.
Replace the tail light fuse (located in the passenger footwell) and bingo... headlights go down. Tail lights AND fog lights work (they appear to be on the same fuse)...
The front OEM bulbs used for DRLs have two filaments:
  • One for the DRL/Turn Signal
  • One for the Parking Light
It seems the short happened in the Parking Lights circuit, which is shared with the Tail Lights, under Fuse 6 in the passenger's foot well fuse block.
Knowing how that was affecting the opening and closing of the headlights would be very interesting...
On the other hand, that blown fuse should not have affected the Fog Lights. These are protected by Fuse 6 in the under hood fuse block
To Light problem... headlights won't go down
