charging system fault
Old Jan 25, 2006 | 06:41 PM
Markm10431's Avatar
Markm10431
Parrothead
St. Jude Donor '08-'09,'13, '14
Default charging system fault
when I started the car to come home Charging system fault flashed on the DIC. it cleared itself immediately, and the gage read 14 volts all the way home. when i got home I ran diagnostics with no new codes. I turned the engine off, left the key on, turned on everything electrical and watched the battery readout on the DIC. it ran down to 11 V pretty quickly. I starte the car and it slowly climbed to 13.4. turned everything off but let the engine run and it stayed at 13.4. my only concern it the difference between the 14v on the way home and the 13.4 at home. Im assumming that since it climbed back up with the engine on and no codes that the charging fault was some fluke.. or do I have a problem?
Old Jan 25, 2006 | 07:43 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
You Do Not have a problem !
Old Jan 25, 2006 | 08:32 PM
Markm10431's Avatar
Markm10431
Parrothead
I didnt think so but where my baby is concerned im paranoid
Old Jan 25, 2006 | 08:46 PM
Evil-Twin's Avatar
Evil-Twin
Just a momentery glitch. Dont sweat it.
Old Jan 25, 2006 | 09:12 PM
turboc5's Avatar
turboc5
If anythang, a weak battery. However I'm sure it is just fine. Just keep your eye on it if you are worried.
To charging system fault
