Battery Drain
Old Jan 26, 2006 | 12:11 PM
87gn's Avatar
87gn
Default Battery Drain
My 03 ZO6 Ended up with a dead battery Monday. I charged it full, It started fine then it was dead again the next morn. Figured bad battery (Red Top 8 months old).
I put in another fully charged red top from the other car, started it everything was fine (It turned over quick and easy) Well it was completely dead the next morning. Not even a dash light.
I did notice that when I replaced the battery that there was quite a spark when hooking up the positive cable. The key was not on so this seemed odd. The car has 20,000 miles not driven in rain, snow etc.
Anyone have any ideas?
I am also searching for a good extended warrranty for this car. The warranty was up last month so can't use G.M. I would like to hear from anyone with suggestions on a good company.
Any thoughts on these subjects would be appreciated.
Old Jan 26, 2006 | 10:05 PM
vette747's Avatar
vette747
I would start to remove the fuses one by one and check how many amps is drained from the battery. You may need a high capacity ammeter since you saw a big spark when you reconnected the battery. Set it up to 10-20 amp first. C5 should not drain more than 30 milliamp. It could also be caused by a faulty aftermarket remote starter or antitheft system.
If removing the fused does not isolate the problem, that means that it could come from a circuit witch is hot all the time. I.e. head light. Most of the time, there is a wire that goes from the battery to the starter solenoid. A hot wire starts from there and provide power to some accessories. You disconnect that wire and check if battery still drains.
Well, you can start by pulling fuses one by one on the passenger foot well and under hood fuse panel.
on a side note, I saw two posts of C5 draining batteries because the interior light were always on. Please check on dark garage.
Old Jan 26, 2006 | 11:37 PM
DragMan's Avatar
DragMan
Cruise-In VII Veteran
mine done that and if I unplugged Dr seat it would stop.
Old Jan 27, 2006 | 06:39 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
When you got your gigantic spark, were you bolting the positive cable first? Negative last?
Old Jan 27, 2006 | 08:22 AM
DeeGee's Avatar
DeeGee
Originally Posted by vette747
........on a side note, I saw two posts of C5 draining batteries because the interior light were always on. Please check on dark garage.
I did that once but caught it before I caused a problem. :o Well worth checking
Old Jan 27, 2006 | 11:05 AM
87gn's Avatar
87gn
Tried it both ways. Big spark. Never a problem before this, no warning at all on this one.
Old Jan 27, 2006 | 11:20 AM
vette747's Avatar
vette747
It was the case for an other guy too. They replaced the seat motor and that cured the problem.
Old Jan 27, 2006 | 08:52 PM
ronwc's Avatar
ronwc
Seat switch -
Old Jan 27, 2006 | 10:20 PM
87gn's Avatar
87gn
Originally Posted by ronwc
Seat switch -
Wow what a great bunch of guys, Keep em coming.
Old Jan 28, 2006 | 06:21 AM
3 Z06ZR1's Avatar
3 Z06ZR1
That makes no difference. Either makes or brakes the circuit'
Old Jan 28, 2006 | 09:32 AM
Alex D's Avatar
Alex D
Seat switches have often been a problem in these cars. Would check a little closer and see if any of them are warm to the touch or unhook all of them then one-per-day re-connect them and see if teh drain occurs again
Old Jan 28, 2006 | 10:33 AM
Lovin It!!! - C5's Avatar
Lovin It!!! - C5
Had this exact issue with my passenger seat. The deflate side of the lower lumbar switch had failed and was constantly on. Switch felt perfectly normal, had spring action, clicked when pushed, etc.... Knew something was really wrong when I touched the lumbar control board and it nearly burnt my hand.
New switch pack ($100 @ the local stealership) and no more dead batteries.
Good luck with yours! Hope you find it before she eats another battery.
Old Jan 28, 2006 | 07:08 PM
thewakeboarder's Avatar
thewakeboarder
I had same problem with my drivers seat lumbar a couple weeks ago. I'll I've done so far was pull the fuse. It's worked so far, but no lumbar (I don't care)... good luck.
Old Jan 29, 2006 | 10:25 PM
87gn's Avatar
87gn
Well, I have pulled all the fuses and still the same. This is a very large spark and the problem is draining a fully charged battery overnight. I was hoping it would be something like the seat ( Drivers only is power-no Lumbar ) pulled the fuses no change. Everything in the car works as normal and it starts right up with a charged battery. No messages on the dash. The more suggestions the better. Thanks to all & keep them coming. The ZO6 has a bit over 20,000 miles on it and is garaged, no rain, still smells and looks like new.
Old Jan 30, 2006 | 08:17 PM
vette747's Avatar
vette747
I never had similar problem on my C5, but since you have not got any other reply or suggestion, let me try to help.
Did you check if they are any codes? When you removed all the fuses I assumed you also removed the fuses from the passenger foot well. Next, I would try to remove the micro and mini relay. Sometimes they are difficult to remove but they come out. You can also try to disconnect the two red wires from the alternator.
To Battery Drain
