Think My Fuel Pump Is Dead.
Old Jan 28, 2006 | 09:27 PM
priscilla ls1's Avatar
priscilla ls1
Default Think My Fuel Pump Is Dead.
I think my fuel pump is dead i turned the key and the car tries to turn but it wont. when i turn the key to the on position the pump makes no whining noice. can it be any other problem.
Old Jan 28, 2006 | 09:44 PM
dpd's Avatar
dpd
you could check fuse 20[fuel pump],could be a relay,could be a pcm.check the car for faults,see if it stored anything.most likely though the fuel pump went poof.
Old Jan 28, 2006 | 09:55 PM
priscilla ls1
fuse 20? is that under the hood or in the passanger kick panal? which one do i check?
Old Jan 28, 2006 | 10:03 PM
dpd's Avatar
dpd
the fuse you want to look at is #13 which is a 20amp[my fault].it is under the hood,it says f/pmp
Old Jan 28, 2006 | 10:05 PM
priscilla ls1
Thanks. how do i test it?
I have one of those tester deals in my trunk it has like a clamp and a with a wire and a needle with a tiny light bolb at the end? am i suppost to use that? do i clamp it on the battery?
Old Jan 28, 2006 | 10:16 PM
dpd's Avatar
dpd
ok,the tester deal i'm assuming is a test light[clamp on one end and at the other end a metal point in a case with a bulb inside].take the clamp and hook it to the negative battery cable[black cable],turn the key on,but don't try and start it.if you look at the top of the fuse you will what looks like 2 silver dots,1 on each side of the fuse rating[20],now take the pointed end and touch one of the silver dots,the light should light up,then check the other the same way,it should also light,if it doesn't the fuse is blown,replace it.
Old Jan 28, 2006 | 10:22 PM
priscilla ls1
cool!
if it is my fuel pump. how do i know if my warranty is expired?
Old Jan 28, 2006 | 10:29 PM
dpd's Avatar
dpd
it is probably out by now.your car is a 02.warranty is 3/36
Old Jan 28, 2006 | 10:31 PM
priscilla ls1
yeah i beleve it is. i need to buy a warranty. parts and labor for this pump will be like a $700 bucks. if its the pump.
Old Jan 28, 2006 | 10:35 PM
white90conv's Avatar
white90conv
The pump only makes a noise for a couple of seconds when you first turn on the key. It then shuts of until the engine starts. There are other things like relays etc. that can prevent the car from starting. This needs thorough checking before assuming it is the pump.
Old Jan 28, 2006 | 10:36 PM
dpd's Avatar
dpd
you can try,but i think you're out.on your car you run the old fuel system,the pump is pretty easy[no need to drop the tank,i think]
Old Jan 28, 2006 | 10:37 PM
priscilla ls1
when i turn the key it will not make anykind of noise. it used to whin a little but now it wont make nothing.
Old Jan 29, 2006 | 12:07 AM
priscilla ls1
I tested the fuse box fuse 13 will not light up but nither will the top half of the fuses. the 6 big ones light up and a couple of the small ones on the bottom do but the ones on the top half don't. anyone know why?
Old Jan 29, 2006 | 07:40 AM
dpd's Avatar
dpd
was the key on?
Old Jan 29, 2006 | 09:20 AM
vetterdstr's Avatar
vetterdstr
CA Events Coordinator
Buy a $35 fuel pressure gauge and hook it up to the shrader valve on the end of the fuel rail... if you have constant fuel pressure... the pump is fine.
VR
Old Jan 29, 2006 | 09:41 AM
Ttime's Avatar
Ttime
VR
Exactly what I would try after checking the fuse. I would also check the fuel filter.
Old Jan 29, 2006 | 09:43 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Mark
Your best bet is to purchase an inexpensive Volt-Ohm Meter from Radio Shack or Wall mart and learn how to use it. The other half of the power equation is the ground system. Does your fuel gage work? The fuel gage and fuel pump is grounded by the same ground G-401.
You also have a fuel pump relay. Some of the fuel system is monitored by the DTC. See if you have any error codes:
Here is a TECH Tips link on reading codes:
https://www.corvetteforum.com/techti...D=26&TopicID=1
Here is a web link:
This is the absolute best C5 Code web site!!!
http://www.corvettedoctor.com/index.html
http://www.corvettedoctor.com/index-1.html
http://www.corvettedoctor.com/Code_Main.html
The sound effects are cool too!!
If you had a fuel system related DTC it would likely be DTC P0230 (Fuel Pump Relay Control Circuit)
The fuel pump relay is in the under hood electrical center and it is Relay#35
Some times there are other relays in the fuse panel that have the same part number and you can swap them to see if that is the issue. Give that a try.
Bill C
To Think My Fuel Pump Is Dead.
Old Jan 29, 2006 | 09:57 AM
priscilla ls1
Originally Posted by Bill Curlee
Mark
Here is a web link:
Bill C
HEY BILL my fuel gage does not work. so does that mean that it is an electrical problem. I get alot of error messages like reduced engine power.
Old Jan 29, 2006 | 10:02 AM
dpd's Avatar
dpd
more than likely,yes.what faults do you have? have you suffered from leaking battery syndrome?
Old Jan 29, 2006 | 10:03 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yep,, That would be my first bet! Get that meter and start looking for that bad component, loose wire or a bad ground! I will see if I can get you a schematic to look at.
Bill
