Seat Cushion Replacemet
The bottom cushions take a most beating. If your passenger seat is OK, you could get away with just the cushion on the drivers side...
the seat has to come out, Easy job, remove the four bolts and the elec harness connector. When removing the seat be careful of the seat tracks, they will easily scratch your rockers , so protect them with a blanket. Seats come out easier if you remove the top, if you have a Vert or a coupe.
Buying the foam is best done through Gene Culley at Fred Beans, he is a CF supporting vendor. You have three pieces of specialized foam for each seat. 1) bottom cushion, 2) back surround 3) back center section.
The lower cushion is around 40 dollars plus shipping.
Check with Gene it may be less Email him the question and supply your Vin #
Gene Culley
Parts Manager
Fred Beans
gculley@fredbeans.com
Here is a great tip for you:
when you replace your lower seat cushion foam, remove the old foam and cut the skirt off it ( the four sides the go around the lower portion of the seat). Take the remaining center section ( the section with the Velcro ) Put it inside the New foam, so in effect the New foam will the twice as thick where your butt contacts the seat. Once you put the seat skin back on you will not notice any difference but the seat foam will be alittle more dense and alittle more comfortable.. No need to throw the old foam away when it will enhance the new>
Good Luck
Bill aka ET
Good Luck
Bill aka ET
I have posted that tip for three years. You must have missed it. I happen to be a wealth of useless information about this car.
As ET stated, you can get the bottom cushion from Fred Bean's and it is a fairly easy install. The hardest part for me was getting the seat Bezel back on (where the seat controls are) without cracking it, etc. Good luck! Definitely worth the time & $$$.
Take a new cloth baby diaper lay it on top of the wires fold the sides over the last wire on each side cut several slits to run small zip tie through. Zip tie and your done.
The diaper will help the foam from splitting in theory.
I did this a few mos ago when I did my seat cover's and foam replacement. I let you know in a year if it worked.
Below is a pic a bad one but you will get the idea.
If so, I'm doing it tomorrow!!
