Borla XR-1
I installed LGM LTs, SLP 3inch Cats, a custom Xpipe and Stingers, LS6 intake and a shaner TBody and made 335HP and 353#ft. torque with an LS1Edit tune.
Then with a heads/cam packages and the LGM LTs, SLP 3inch Cats, a custom Xpipe and Stingers, LS6 intake and a shaner TBody I laid down 375/370 to the wheels with a custom LS1Edit tune.
THEN, about three weeks ago I went back to the dyno for the Corvette Forum day at Carolina Auto Masters and with a change to the Bassani Xpipe and the Z06 Mufflers, and a mild re-tune to clean up the fuel map, we picked up an additional 11HP and 10#ft. torque. I'm at 386/382 now.
And the car sounds much better when on the hiway. No resonation or droning.
My personal opinion is those Borla XR1 Systems don't add ANYTHING to your performance... They, like many other makers of aftermarket parts are marketing an item and want your money... They claim "Up to" XX % performance gains... Up to, or less than.
I experienced the "or less than" part of it!
Mike
Mike
It's definitely loud, and definitely gives a loud hum inside the car at 1500-2500rpm under throttle, but above that, and cruising, it's pretty quiet.
Like someone said previously, everyone, including myself, hears it when I get on it.
If you're going to get it, and leave it stock with the cats in tact, it's not bad at all. Again, like others have said - it's VERY exotic-sounding. I wanted a bit more, so I removed the cats, and of course, everything's a bit louder.
As far as power goes, I don't have dyno numbers but there's definitely more, to the point where I'm looking to upgrade my tires to reduce wheelspin. Plus, I never hit the 1-4 skipshift anymore - sounds too good to shift low!
