Replacing Oil Pressure Sensor Questions
Old Jan 29, 2006 | 06:53 PM
Oldvetter's Avatar
Oldvetter
Default Replacing Oil Pressure Sensor Questions
Well my oil pressure gage pegged at 80 psi and DIC read 129 psi, so I guess I had better replace the sensor.
-Shop manual calls for putting GM part number 12345382 threadlock on intake manifold bolts, is this Blue Loctite ?
-Should I replace or reuse the manifold gasket ?
Old Jan 29, 2006 | 07:05 PM
muncie21's Avatar
muncie21
Depending on miles, you can most likely reuse the intake gaskets. BTW, they are individual o-ring gaskets, not two big gaskets like in the older engines. When my OP sensor went out at 50K miles I re-used the gaskets. First replacement sensor failed in less than a day, so I ended up pulling the intake twice, used same gaskets both times....no issues.
Old Jan 29, 2006 | 07:26 PM
Oldvetter's Avatar
Oldvetter
I have heard about these new sensors failing, did you use a GM sensor?
Maybe I should try a NAPA or Auto Zone part?
Did you use locktite on intake bolts ?
How long did it take you to replace ?
Old Jan 29, 2006 | 10:49 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
You want to use anti sieze on the intake bolts, and torque to spec.
To Replacing Oil Pressure Sensor Questions
