Pull Motor??
Old Jan 30, 2006 | 05:03 PM
Casem1's Avatar
Casem1
Default Pull Motor??
OK, thanks to the Hurricane Rita evac I need a new clutch. I will likely add an LS6 assembly, complete with flywheel. I am also interested in a cam swap and header install. Would pulling the motor be easier to reach both objectives at once or would a rear suspension/tranny/torque tube/radiator/steering assembly drop be better (as these are the common procedures to reach each objective separately).
Old Jan 30, 2006 | 06:08 PM
mdhmi's Avatar
mdhmi
I would do the LS7 clutch over the LS6.
Mark
Old Jan 30, 2006 | 09:36 PM
Casem1's Avatar
Casem1
Isn't more required for a LS7 clutch swap?
Old Jan 30, 2006 | 09:49 PM
C5 KIDD's Avatar
C5 KIDD
Cruise-In VI Veteran
dont do LS6 clutch. its a waste, and you will run into problems later on.. especially if you are going with cam/headers! do a search for "sticking clutch pedal"
Old Jan 30, 2006 | 10:41 PM
turboc5's Avatar
turboc5
How did the Rita evac affect your clutch? BTW I have a texstrallia clutch and love it but if you go the oem route check out the ls7 with a ls2 flywheel set up.
Old Jan 31, 2006 | 08:40 AM
Casem1's Avatar
Casem1
14 miles in 8 hours.... 5-10 feet at a time. My left foot was numb. If you didn't stay on the bumper of the car ahead of you you lost your spot. My clutch was really shakey and required a lot of slippage by the end of the evac. After it sat for a day it was OK for driving around during my first drag attempt a few days back the runflats hooked up better than the clutch. I am not kidding. I could only smell clutch. The car has only a few boltons and 18k miles so I don't think that is normal wear and tear.
Maybe FEMA will reimburse me
Old Jan 31, 2006 | 08:41 AM
Casem1's Avatar
Casem1
Anyway, regardless of what clutch I use, which option for replacement would be better with a cam swap at the same time?
To Pull Motor??
