EASY location for Raptor tach input?
Old Jan 30, 2006 | 06:34 PM
MgKenny's Avatar
MgKenny
Default EASY location for Raptor tach input?
Just got my Raptor shift light in the mail. According to their directions, I need to access the PCM under my passenger wheel well and tap into green connector c2 pin # 10, white wire.
Has anyone done this before? Is there an easier place to get a tach signal for the shift light? If not, can I get in there with the car on ramps or am I going to have to jack the car up and remove the front right tire?
I've got the other wires covered, just need the tach input.
Thanks in advance!
Ken
Old Jan 30, 2006 | 08:04 PM
cmeflyby's Avatar
cmeflyby
From: Alhambra Calismognazifornia, in the country everyone comes just to complain but won't go back home!
definitely and easier spot available...
it's under the dash on the driver side. there's a big bundle of wires with 3 white (fairly sure that's the color) wires. one of those is the one you need....
i don't remember any more details as i did this a while back.
do a search on the topic and you'll probably find some writeups. i stuck a small straight pin in the white wires one by one (got it on second try) to probe for the correct wire and then just used a wire tap.
Old Jan 30, 2006 | 08:24 PM
Patches's Avatar
Patches
http://forums.corvetteforum.com/showthread.php?t=619162
Old Jan 30, 2006 | 08:49 PM
MgKenny's Avatar
MgKenny
Thanks for that guys! I may even install it tomorrow instead of this weekend as it will be ALOT easier.
I knew asking on this forum would be the answer!
For the trouble you saved me...I owe you guys a beer!
Now that that's out of the way, where would YOU mount the shift light?
Thanks again!
Ken
Old Jan 30, 2006 | 09:51 PM
3Vettes@Home's Avatar
3Vettes@Home
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Thanks again!
Ken
I mounted mine on the a-pillar trim just below the visor (used double back tape), works great
Old Jan 31, 2006 | 02:17 PM
cmeflyby's Avatar
cmeflyby
Ken
now that has been the big problem for me. i wanted it up in the corner of the a-pillar and tried double-sided tape of various types, and industrial strength 3m velcro (industrial strength adhesive) and it never lasts. the car gets too hot inside and the adhesive turns to mush letting the light eventually dangle from it's cord . the easiest and most secure way, of course, would be to just screw into the a-pillar cover but i didn't want to do that.
good luck!
Old Jan 31, 2006 | 06:42 PM
MgKenny's Avatar
MgKenny
Ok. Installed it tonight. What an EASY install. It took me longer to figure out where I wanted the shift light than it did to actually install it! (I put it about eye level on the A-Pillar...1 screw and you're done!)
Works great and looks cool too.
Thanks for all the good info. If I would have pulled a tire and then found out about this I would have been pi$$ed!
Ken
Old Jan 31, 2006 | 07:40 PM
Patches's Avatar
Patches
On the A-pillar initially
The custom mount I made
Old Feb 18, 2006 | 07:53 PM
tazinhawaii's Avatar
tazinhawaii
I'm in the middle of intalling a dyno tech wideband and am trying to tap into the tach signal at the PCM (already ran the wires). But I don't have a 'green' harness. Mine are red and blue. The blue has 3 gray wires, but I can't find a white one. The red has a bunch of white wires. Which one do I go to???? Help please.
Derrick
Old Feb 18, 2006 | 08:25 PM
Patches's Avatar
Patches
On the red harness, look at the end of the connector directly with the lock tabs facing up. You should see faint markings at the corners of the connectors. Look for the little "1" on the lower left corner of the connector that will be next to pin no. 1. Count ten over on the bottom row. That is pin no. 10 which should be the white tach signal wire.
Old Feb 19, 2006 | 12:27 PM
Lemansblueboy's Avatar
Lemansblueboy
Great thread on the raptor hook up, will not wait any longer to get one, Any expert advice on which of the four LED colors is the most visible from the corner of your eye and where to get the best price?.
Old Feb 19, 2006 | 12:58 PM
Lemansblueboy
Thanks in advance!
Ken
Nice thread on hooking up the raptor, now I will order mine, What color LED did you choose? and did you choose it based on visiblity or color match. Also where did you order from.
Old Feb 19, 2006 | 07:57 PM
Patches's Avatar
Patches
They are all so bright it really comes down to color preference rather than visibility. I got the blue LED with black body.
http://www.raptorperformance.com/
Old Feb 19, 2006 | 09:15 PM
MgKenny's Avatar
MgKenny
Ditto here on the Blue/Black combo. It is VERY bright with the cover off. I got the Black tube to match the interior and I'm a sucker for Blue so that's why I got that color.
Their website has alot of info on the different colors.
It's a great setup, just take your time with the install. I took the advice in one of the links above and tapped into the pink wire in the same harness for ignition power. Grounded it right to one of the screws that holds the bottom dashpad in and it was done.
Old Feb 20, 2006 | 04:13 PM
Lemansblueboy
Just ordered the blue LED with silver casing, The raptor web site says blue seems to catch the eye a little more. Can't wait' more toys
To EASY location for Raptor tach input?
