head and cam question
Old Jan 31, 2006 | 11:54 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
Default head and cam question
anybody have sugestions on a h/c for a 2000 a4. looking to make good power but its got to be streable and reliable. i already have a 2400 stall and 3:42 rearend. also a aluminum radiator and tranny cooler. so i am all set up. i just need a few specs and sugestions. any thoughts would be great.
Old Feb 1, 2006 | 08:12 AM
LT4BUD's Avatar
LT4BUD
Victory Engines on Lorain Ave...just west of 150th street does great work on heads......they did mine.....they are real craftsmen...
Go see Ray....tell him Bud with the LT4 sent you....
Rottie has used them on several of his projects.....
http://www.victoryengines.com/MainFrame.htm
Old Feb 1, 2006 | 08:51 AM
Carbotech Adam
Supporting Vendor
lt4bud, thanks for all your help on this matter. i am waiting to see what rottie comes up with as far as heads we might use a ls6 or a afr. but for cost we were thinking of using the ls1 head but that means giving up some power. once again thank you for your help
Old Feb 1, 2006 | 09:05 AM
9T3JIM's Avatar
9T3JIM
Looks like you and I are after the same thing, I also talked to Rottie last night about a H/C package. I already have a set of 243 heads and a Z06 intake manifold, waiting to see what Rottie recommends for a cam.
Old Feb 1, 2006 | 09:18 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
PM Alex1217.
He has a nice setup making 407 at the rear wheels. Here is his setup from his profile
Blackwing Air Filter, Carbon Fiber Air Bridge, Ported TB/Oil pump, NGK TR55's, AFR 205 CC Heads, 224/230 Cam, Comp 921 Springs, Kooks LTs Headers, high flow cats, X-pipe and Z06 Titanium Exhaust
Old Feb 1, 2006 | 09:44 AM
Alex1217's Avatar
Alex1217
St. Jude Donor '08-'09
Hey Stunna,
I wanted the same thing out of my Heads & Cam package. I wanted the vette to remain very streetable, reliable and comfortable. I spoke to Chris and Doug at ECS and went with a 224/230 Cam with AFR heads. Like Wicked Weasel said, I ended up with 407 rwhp and got everything that I wanted out of it. There's no stalling, no shaking, no surging, just a nice low rumble at idle and a nice lopey sound when you listen to the exhaust. The difference in power is like night and day, I was spinning my runflats at half throttle till I got new rubber on there. Still, its still very comfortable in stop and go traffic and when cruising on the highway. I love it!!
Old Feb 1, 2006 | 10:01 AM
Carbotech Adam
Supporting Vendor
i am defeniyley going to go with afr 205cc. my question is why port the oil pump and did you port your stock throttlle body. i like the cam suggestion. i was also thinking of using a a evac pump for the oil. also what do think about these profiles 226/226 or 232/230 with .58/.58 lift and a 110-112 lsa
Old Feb 1, 2006 | 12:23 PM
blktie8's Avatar
blktie8
Headers ,optional under drive ,KATECH ROD BOLTS ,CHAIN AND OIL PUMP
ETP heads and let ED Curtis design the cam
The Katech stuff is a must at 6000rpm plus on a 2000 or older
Do the Z06 VALLEY COVER
LS6 OR BETTER MANIFOLD
DONE in 20 hours pulling the engine
Say goodnight to your transmission
Old Feb 1, 2006 | 01:38 PM
Carbotech Adam
Supporting Vendor
i have headers and ls6 intake manifold already who is etp and ed curtis
Old Feb 1, 2006 | 02:13 PM
Face's Avatar
Face
If you want streetable, be sure it's at least a 114 LSA.
blktie8's Avatar
blktie8
Ed Curtis
E-mail Address(es):
EdCurtisFTI@***.net
Personal Information:
Phone: 401-828-9302
Business Information:
Address:
401-828-9302
Tuesday, Wednesday and Thursday in the afternoon is best.
Ed
Phone: 401-828-9302
ETP HEADS
http://www.etheads.com/mainpage.htm
Old Feb 2, 2006 | 01:46 PM
Carbotech Adam
Supporting Vendor
what kind of fuel injectors will i need to run a h/c package.
Old Feb 2, 2006 | 02:03 PM
nightmel's Avatar
nightmel
also Texas Speed and Performance has 243 CNCed and Ported Heads that Flow better numbers than my AFR 205's for $899.00 a pair. Great Deal on cams also check them out @
www.texas-speed.com or call them and talk to Jon or Brian, @(806)866-0734, they can give you a great price and great customer service. and good luck!
Old Feb 2, 2006 | 02:04 PM
nightmel's Avatar
nightmel
Stock will be fine.
Old Feb 2, 2006 | 02:07 PM
nightmel's Avatar
nightmel
These are some monster heads, great numbers and great heads but will cost you. I haven't seen any for less than $2300.00 if anyone has let me know I'm thinking of going this route.
Old Feb 2, 2006 | 04:46 PM
blktie8's Avatar
blktie8
2000 fuel injectors are 26 lbs
newer injectors are 28 98 injectors are 28 We with 99 and 2000 are 26lbs
I would get svo 30 's so you have a little room
28 might be ok but it all depends on the HP you want to make.
That's engine HP
Some vendors have a calculator to figure the size at 80% duty cycle
Maybe racetronics
John
Old Feb 2, 2006 | 05:39 PM
kendo347's Avatar
kendo347
QUOTE=blktie8]Ed Curtis
E-mail Address(es):
EdCurtisFTI@***.net
Phone: 401-828-9302
Address:
401-828-9302
Ed
Phone: 401-828-9302
ETP HEADS
http://www.etheads.com/mainpage.htm[/QUOTE]
If you get etp heads they are on severe backorder.
To head and cam question
Old Feb 2, 2006 | 05:53 PM
Laguna Blu's Avatar
Laguna Blu
Rather than go it alone and choosing your mods a-la-carte, discuss your power & streetability goals with a reputable tuner and let them suggest the right package for you.
Old Feb 3, 2006 | 09:46 AM
Carbotech Adam
Supporting Vendor
WHAT KIND OF POWER ARE YOU MAKING. FROM YOUR VETTE DR SET UP
Old Feb 3, 2006 | 10:03 AM
Face's Avatar
Face
I hope he doesn't mind me answering for him. IIRC, he has over 400rwhp from his package, and it's a few years old now.
